Artevanj
Clardy or HobieDave AC bracket needed
7 posts / 295 viewsLast Reply
we manufacturer our own brackets.  We can tune it a bit to early model or late model cars.  Designed to work on early model cars without the high bolt mounts on block and to work on later model cars with the high bolt mounts the Hobie Dave bracket requires
Also have new tensioners and pulleys as works better with pulley and tensioner
http://www.dtechparts.com/ac-compressor-bracket-for-bmw-2002-m10-engine/
2 hours ago, Artevanj said:
Not sure how to private message on this forum
You simply move your cursor over the avatar, or screen name for the person you want to send a message to and then click on MESSAGE at the bottom left of the window that opens.  Then type away and click SEND when you are done.  You can set up your preferences to receive email notifications of incoming messages... or it may be set that way by default.
cheers,
Tom
