bimmer_b
Go to solution Solved by Tommy,
11 hours ago, fjord-tii said:
@bimmer_b I used Parker in Greensboro for yellow zinc (“cad”) plating, You might want to get everything as clean as possible with a very fine grit/polish compound in a vibratory tumbler. I didn’t and it shows :(. It still looks great, though, compared to plain zinc.
I’m going to take it to a place in Maryland that will clean it and recoat it.
Ana B.
Check out my 2002tii restoration :D
More random BMW/2002Tii Posts ? https://www.instagram.com/bimmer_b/
Please let us know who you use to refinish the hardware.  Thanks!
John in VA
It’s call Metro Plating. I’ll let you know how it turns out. I’m taking some trim pieces to them too to see if they can remove some dents/dings and polish them.
Ana B.
Metro polished the sunroof pieces for my 69.  They were recommended to me by Raine and Lothar.
On 10/13/2018 at 7:29 PM, jgerock said:
Excellent.  I would certainly recommend them.
I took my hardware there only to have them say they don't do zinc plating so I will have to find another place to do it. I left a trim piece for them to take dents out of and polish so hopefully that comes out good considering they charge per 3/ft of trim.
Ana B.
There are other places that do the zinc.  I've heard of a place in MI and one in NC.
Edit: believe the place in NC is called Pugh's Plating.  Mike Pugh (no relation to the shop) told me about this a few years ago. I don't have any experience with them.
Edited by jgerock
Could they not recommend a place that offers plating?
John in VA
I just called a place in Richmond and they will do it. It's $55 to clean and then minimum charge of $131.13. Kind of expensive for some nuts and bolts, so maybe I will try to find some new hardware since that will be cheaper then sending out and replating. Is all the original hardware supposed to be the yellowish colored or silver zinc color?
Ana B.
This is a long time debate of many owners.  Some promotional ads featured zinc plated hardware, others just standard hardware.
Walloth Nesch sells complete hardware kits that have the yellow colored plating.  That's what I used on my 69 project and the recent front subframe refurb. of my 73tii.
Here are some pictures of Bruce Hall's incredibly original 72tii
I have all the engine compartment together. I mostly just need door component pieces like the outside handle attachment bolts and window regulator pieces cleaned and redone.
Ana B.
Since this hardware is rarely seen by most folks, a good cleaning is all you really need to do.
