Auto tranny pulling "whoa nellie" ? Please help. .
URL: http://sleekboata.tripod.com/
I just got this car on the road finally and the trans is chirping the tires when I put it in gear. Pulling very hard at idle when it should not. I can't drive it because it is hard to stop (it is overpowering the brakes.)
Is there an auto tranny FAQ? I was unable to find any info in the archives. How is this thing controlled? I know nothing about automatics. I am assuming that I need to change the fluid and filter and pan seal. But I have no clue on adjusting the "idle" however that works.
TIA
Will
Smyrna, GA
which means its something internal :(
I assume you already checked if your idle is normal.
it'll be hard to restrain when stopped at a traffic light, etc. Check this first...
Mike
will be about 1100-1200. I been driving automatic '02s for 23 yrs., and have never had the problem you're describing. (Currently have a '76 and a '75 auto). Post above about internal problem may be correct.
