Hose Set for tii
David Layton
56 minutes ago, Son of Marty said:
The real advantage of the silicone set is they will last much longer than the rubber set and they can be cleaned easily if thats important to you.
The downside — and this is purely my opinion, not fact — is the appearance of silicone hoses: slick and shiny. I, for one, believe that “flexible” and visible automotive components — my definition of “flexible” here embraces rubber and silicon hoses — should not be shiny, like painted metal components. My tires, for instance, are black, but they are not shiny. And my hoses are black, but not shiny. I may be in a minority, but I would view a silicone hose as out of character in a 50-year-old car.
I won’t dispute the longevity of silicone hoses, although I’ve yet to see a 40-year-old silicone hose, whereas I’ve seen 40-year-old rubber hoses still in use.... ?
So, are there forum members here who see rubber hoses failing in five years? Ten years? Mine tend to last a long time, much longer than most people keep most cars. And how long are you going to keep your car? Is the buyer going to love your silicone hoses, or not?
My input....
The photos below reflect my aesthetic, YAMV (“Your Aesthetic May Vary”)! Check out my dull XAS’s...
Edited by Conserv
  • Like 4
I'm also with Steve I prefer the rubber look over the shinny or colored hoses but thats  my opinion and if I did get a car with silicone hoses I'd just leave them on the car, I know that silicon hoses last many hundreds of thousand of mile on semi trucks but 02 have much lower underhood temps than most new cars and the way most are used these days, IE weekend drives, most of the real advantages of silicon are moot.
PS  when I drove my 02's as daily drivers and track days I did change the hoses about every 5 years.
Edited by Son of Marty
George S Patton
15 minutes ago, jerryasi said:
my question is to Conserv, whose relay rack did you use under hood?
That’s the factory 4-slot relay rack that came on all square taillight cars (1974 models through the end of 1502 production in 1977). Three slots were filled from the factory (low beam, high beam, and horn) unless you had factory-installed fog lights (the latter was not available from the factory on U.S.-spec cars). I have fog lights, and driving lights, now. I use the extra slot for the fog lights and there is a fifth relay mounted to the inner fender, just below the relay rack.
Edited by Conserv
4 hours ago, PaulTWinterton said:
No.  Most of my replacement hoses are near 20 years old, but I admit they aren't overly abused.
I'm with you Steve.  I prefer the stock rubber look.
I go through the pain every ~5ish years with stock rubber along with replacing my KF belt.
PM is preferred to the side of the road.
Colin K.
Malaga '72 tii
Wow, Colin,
Would you consider yourself fairly risk-averse, or have you witnessed actual failures of hoses and KF belts within five-ish years?
Best regards,
With the silicone hoses, has anybody scuffed them up a bit to diminish the sheen?
I got an IE set for my tii. I am currently on the performance/durability mode for our rallies. I'll look under the hood and go "Good, good, good..." rather than "Correct, correct, correct."  If the body ever gets repaired and painted I might revert back to bone-stock.
Edited by SteveJ
Steve J
& too many bikes
Perhaps there is a flat/matte paint one could use on the silicone hoses.
John in VA
+ 1 on non-shiny hoses
+1 on non-shiny size correct / period correct tyres with tubes (XAS on left, Sumitomo on right).
Any society that would give up a little liberty to gain a little security will deserve neither and lose both.
Benjamin Franklin
73 tii (Verona, survivor, owned since '92)
66 DS21 (most technologically advanced car of the 20th Century)
3 hours ago, Conserv said:
Wow, Colin,
Best regards,
I am risk averse.
The only time I was stranded was when my KF belt broke back ~'78 (may have been the original belt) and yes I keep a trunk full of spares.
I've had the heater hose leak when I lived in So Ca (Venice area) so they got included in the that rotation.
I also change the fuel filter every couple of years to avoid sputtering down the road. Regular fluid changes (brake and radiator) are all part it.
Besides that, I have to skin my knuckles every so often....
I think I'm due for fuel lines but I need to check my maintenance log...
Colin
Colin K.
Malaga '72 tii
Jeez, a year’s worth of engine bay grime is all it takes to dull the shine a little.
(Fit from IE is good, although I did have to call for one was missing, sent out no issues)
Now I wouldn’t do the blue hoses... that’s where I draw the line
