deschodt 59 September 24, 2018 At some point I had MC issues which devolved into booster issues while at the mechanic's. I ended up with a good used booster (#3 as I recall, mine was bad, another replacement was bad, finally got one that worked) and a Tii master cylinder. My car is NOT a Tii but I believe is has rear brakes from a later car. Pedal feel used to be perfect, boosted but you could push the pedal and feel what you needed to feel and brake well... Now, the pedal is too hard - there's some boosting (because of the booster failure I know what zero boost is like and that's not zero) - light braking feels normal, but it's a really hard pedal after the initial push for more serious braking... Locking wheels is possible ( I tried) but you have to be motivated and seems to me the effort required is abnormal... Question is: I'm not sure why the mechanic put a Tii M/C in my car. Could that alone explain the poor pedal feel and harder force required? OR, is that OK and not all that significant and my booster is failing again ? Any simple test I can do with determine which is guilty, or common knowledge ? Thanks ! Greg. Share this post Link to post Share on other sites
TobyB 2,470 September 25, 2018 Yup. that could do it. Tii m/c is quite a bit larger for the larger tii calipers. That will give you less pad pressure for the same pedal pressure. You could use vented Volvo calipers in front (with late e21 hubs and 77 e21 rotors) to split the difference... t 1 Share this post Link to post Share on other sites
Schnellvintage 121 September 25, 2018 Did your mechanic replace the booster hose(s)? Check to make sure the vacuum check valve is installed properly the arrow should point in the direction toward the intake manifold. Not the booster. Also did he/she use the correct hose, so it doesn’t collapse under vacuum.?Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Tommy 136 2 Vehicles September 25, 2018 Since difference from stock to tii caliper is so big in piston size, 34 to 40mm, I think it's dimensioning issue. That makes 38% more pedal force than tii from the hydraulics only, difference from rotor size adds some. Volvo calipers with 38mm pistons would bring the number to 11%. Share this post Link to post Share on other sites
deschodt 59 September 27, 2018 I see, so upgrade the brakes or reduce the M/C... Thanks for confirming ! Share this post Link to post Share on other sites
