Anyone know how to convert a carb M10 to individual throttle
I have a 32/36 on a 75 2002, but I would like to have fuel injection with individual throttle bodies. Has this been done before? How expensive is it? Is it worth it?
It will cost you $3000 for parts alone, plus 40 hours of installation and weeks of learning internal combustion engines principles... I have been there, done that.
Everything that you could ever imagine has been done, including a M5 engine and all electric 2002. Maybe not...a ram jet engine.
With individual throtles you can either go mechanical of electronic fuel injection. Is it worth it? That's a tough one to answer...
Check the archives...
Ducati 45mm motorcycle throttle bodies, early 320i "stub" manifold (44mm inlets...about perfect), 84-85 318i fuel rail. Combine with megasquirt, drive vigorously. Garnish with fuel injectors.
I'm slowly documenting the whole thing...I'll post it all when I'm done.
Well, I can't tell you, because then i'd have to kill you ;) Na, i'm keeping it under wraps becuase if it doesn't work or whatever, then yeah, then I don't have to do any explaining. Hopefully by about June I can surprise you guys. ITB's seem so cool though don't they, they just look so rad under the hood!!!
Bryan
red73
When you add all those:
SDS software/harware/harness
2 TWM throttle bodies
2 TWM fuel rails
1 TWM fuel pressure regulator
1 TPS
4 Bosch injectors
4 airhorns
Bosch fuel pump and prepum
Aeroquip plumbing ($$$)
KN air filter
aluminum airbox
AF ratio gauge/oxygen sensor
Ducati Throttle bodies (came with velocity stacks and TPS): 140
320i manifold: 40
91 318is intank high pressure pump: 50
84 318i fuel rail and regulator: 15
random bits (hardware): 20 spent so far
Megasquirt: approximately 150
thats around 415 as of now. All thats left is a plenum (home made), filter, injectors, fuel line.
car will run in Alpha-N mode (TPS, temp, rpm to determine mixture) But I'll probly get a O2 and a/f ratio meter as well.
kiss my butt twm :-)
