Water pump pulley bolt?!? Thread size..??
I'm at work and forgot to grab the old ones for the thread size.. I've swapped to an electric fan and the old bolts are wayyyy too long :) thanks greatly
It only solved part of my problem. It still has a hesitation, and I have a feeling that the boost controller has something to do with it. I might just go back to stock boost control for now.
Thanks again for the throttle body.
Eddy
When the intercooler will be finished up, i will re-tune my SDS set-up because i have changed my top green injectors for top browns ford ones, along with a 3 bar map sensor, so then i will raise the boost. The previous set-up and the bar sensor that i got was good up to 15 psi only. NOW i can do a lot more :)
See results in a week or so..
Pat Allen
Where is the hesitation? I bet it's ignition related and not boost.. If you want quicker spool-up let me know, I have a few tricks ;)
