Ooops ,exhaust bolt help
Well not only one week after i saw the post about exhaust bolts comming loose i have started my yellow 72 and saw a lot of smoke. It only took me 4 starts and a 200 yard turn around the block to see one falling out and one gone.
so probably best to get 8 new ones but what is the stuff i pu on the bolt to help them stay put again?
I need to take header off cause one is broken but in there and one leaks pretty bad.
Also i can get her started and idleing for 5 minutes, and she stays at half choke well but bogs out and a quater or less.
Do i need to up (richen) the idles screw? stock solex
Much love from the carb newb
LOOK AGAIN WAY UNDER YOUR CAR AT THE REAR OF THE TRANSMISSION, " GOT SUPPORT BRACKET " ?? Get one and all the tiny bits .
