What is it about 13" wheels
SydneyTii
46 minutes ago, SydneyTii said:
Well I think 13" wheels are great, it's official ?
Couldn't agree more!
Installed these yesterday...
  • Like 7
Tim Dennison
'72 BMW 2002 tii - Malaga,  '02 BMW Z3 Coupe Sterling Gray,  '09 BMW 650i - Carbon Black,  '15 BMW 228i Estoril Blue,  '19 BMW Z4 30 - San Francisco Red
1 hour ago, JohnS said:
The Campys look great.  Looks like they fit pretty well.  Good job!
Thanks, they fit perfectly.
Tim Dennison
  • 2 months later...
On 10/9/2019 at 11:48 AM, DLC said:
Would love some details around this setup!
Suspension?
Offset?
The rims appear to be 6 x 13 Borrani’s (manufactured by CMR, of which Borrani is a division or brand). Assuming that is true, there are two different models in 6 x 13: an ET17 (R1-528) and an ET30 (R1-561). These might be the latter: ET30.
Edited by Conserv
  • 8 months later...
On 10/9/2019 at 5:08 PM, Conserv said:
The rims appear to be 6 x 13 Borrani’s (manufactured by CMR, of which Borrani is a division or brand). Assuming that is true, there are two different models in 6 x 13: an ET17 (R1-528) and an ET30 (R1-561). These appear to be the latter: ET30.
Are those 195 tires? Hard to tell.
I’d guess they’re 205/60, unless they’re 185/70, or even 175/70...
You’re right: hard to tell (but that right rear tire, where we can see a little daylight under the car, looks wide)! ?
Edited by Conserv
I would guess they are not 70 series tires, seem to be 60 or 55 series and since they are far out the ET is closer to a E21 ET. Looks good, looks aggressive but also restrained. Mine looked like that too, but I didn't clear the fenders unless the steering wheel was pointing straight.
Andrew
1971 2002ti, 1985 E30 320i, 1960 Land Rover 109 Ser 2, 1963 Land Rover 88 Ser 2a, 1980 Land Rover Ser 3 Lightweight
Andrew
You may well be right, Andrew. I guess this would be very simple if @revolve40simply weighed in!
With 6 x 13 Borrani’s — and I thought these were 6”, not 5.5” or 6.5” — the offset choices are 17 and 30. But maybe they’re not 6 x 13!
Without further comment or guesses, here are ET17 (left) and ET30 (right) versions of the 6 x 13 Borrani.
Best regards,
Edited by Conserv
With 6 x 13 Borrani’s — and I thought these were 6”, not 5.5” or 6.5” — the offset choices are 17 and 30. But maybe they’re not!
Without further comment or guesses, here’s an ET17 (left) and an ET30 (right).
Best regards,
I am going to build 13” bbs wheels for my m2. The car will be lowered on coil overs and I think I will run 185/60/13” r888r tires. 13x6 is what I think I should get but I wanna make sure the fronts and rears dont rub.
i had bbs001 15x7 et25  and there was an annoying rub on sharp turns. I want no rub at all.
What offset would I need for 13x6 wheels to make sure there is no rub!?
Sure about 185/60? The diameter is way small compared to original. Allright it might work with very low suspension but usually profile 70 fits better with 185.
That's what I have on 13x6 ET30 wheels. I do experience rubbing in track circumstances but I think it's because of my aftermarket fenders. To be sure go for ET35 but usually around 30 should be good.
Best regards,
Well I'm a tad late to the discussion here - thanks for the tag @Conserv
These are actually 13x5.5 and the tires are 185/60/13 R888s.
Edited by revolve40
Really warming to a set of 13” wheels for my 2002.  Tyres seem less of a choice but read though the thread and there are a few interesting choices.  Namely the Yokohama A021r in 185/70/13.  Anyone run one as a road tyre?
1974 2002 2.2stroker, DCOE45's, 300deg cam, 5 spd, 3.91 LSD // 1984 E24 M635csi, dogleg 5spd 3.23 LSD. // 1994 E34 540i, supercharged 16psi, 6spd E85 only, 3.15 LSD // 1997 E36 M3 Evo, low comp supercharged 18psi 6spd (under construction)
