Just bought a 71 2002,can't open luggage compartment
I've tried going thru the backseat,turning,thumping,bumping,bitchin,and I still an't get in the trunk.The PO tells me there are lot's of goodies in the trunk.Any suggestions?
David Dill
89 735iL-200K
71 2002-115K
Make sure you have turned the key in the trunk lock so that it is in the open position. Then you may have to really depress the lock button really well. If it doesn't open the first time, turn the key 180 degrees and try again. Sometimes the lock button release requires a lot of pressure.
Good luck
