Hey DHS and Bobinokc
Do you have any more pics of your cage fabbing, that shows your 'floor cutting' for dropping the cage? I feel like an idiot now, as I'm sure thats 'general practice', but that didn't even cross my mind!
thx
Matt
Just get a hole saw bigger than tubing dia, and make the required cuts.
When you are done, the mounting plates cover the hole on top of the floor, and it's best if you weld from the underside of the floor to tie the hole perimeter to the bottom of the plate (also seals out water intrusion).
Dropping the cage down allows the best access to get complete welds in the tight spots, which is something a good tech inspector will know to review when you first get the logbook & cage stamp.
I did it a little different than most cage installs. I have the hole going through both the shell floor and the actual plate. The plate was welded to the floor and then a hole put though both it and the shell so the hoops actually sticks out under the car.
Link is to the cage pics I have.
