Nice looking head and 45 Weber set up on Ebay
maybe, just maybe, i might go in that direction for the sahara. more juice than the 40/40 . will have to see how week goes. nice loking set up for sure. 286 cam it seems. probably matched just right.
Cylinder head with double carburetors for BMW 2002 to the in 2002 Ti.
Delivered absolute museum piece / merely for reasons of space.
Ready for installation and complete with all parts .
Cylinder head type E12 of the 2002 Tii
(Intake valves 46 mms, discharge 38 mms, fuel space almost half-spherical)
Together with side lid new pan-milled
2 Weber double carburetor with diameter 45, type 45DCOE9
Completely overhauled by renouned motor sport
(New throttle valves, membrane, poetries, nozzles, Bypassbohrungen)
Receipt is enclosed and gives information about the used Bedüsung
One and discharge canals, suction bridges, valve plates,
as well as the fuel spaces are smoothed and are polished.
Suction bridges were adapted on diameter 45 without crossing
Valve guidances with examined passport measure 8H7
More:
Standard camshaft with 286 degrees is inserted
(Sporty enough and provides above all for quietness in the idling)
Bosch distributor of the 2002 Ti
(without low pressure adjustment)
Ignition cable sentence, plug, distributor finger and cap are new
The Gasgestänge is on raised
Shimmer's chambers of the 45th conformist
Rare, long suction trumpets with adaptor rings
for the use of an air filter box
A new choke-installation part is likewise provided,
nevertheless, I recommend the use of the available one
All parts are new,
Cylinder head parts still packed in original
A contemporary electric gas pump is provided
In addition to the mounted Duplex chainwheel. I add one more gearwheel for the easy timing chains
Dispatch.
...if the Euro is stronger, it takes fewer of them to equal a particular number of dollars. Thus, if $1=1.20 Euros, then $1500=1250 Euros.
If $1500=1800 Euros, then $1=0.83 Euros and the dollar is stronger than the Euro, which isn't the case now...
-Dave
