transmission leak- 4 speed
Replaced my speedometer cable and noticed the transmission is leaking. Should I order a gasket for the flange side. That is the major leak but the engine side is also slightly leaking. Should I just use silicone gasket stuff or get the gaskets?
Assuming I get two new gaskets, what is the easiest way to drop the transmission just to stop the leaks. Clutch is in good condition so this is all I want to do.
1973 2002 with a 4 speed.
Also noticed the rubber mount for the transmission and muffler needs to be replaced. Don't know if that is related to the leak.
