11 posts / 2762 viewsLast Reply
Price: $68000
Description:
BMW 2002 tii 1971 “Max”
Logbook: VSCDA, SVRA
Condition: Excellent
Best known 2002 in the Midwest if not the country. Documented racing history goes back to early 1970's and includes Paul Masank's SCCA national wins. Car is often featured in vintage racing publications (most recently in the Vintage Motorsports 2008 Annual). Many VSCDA and SVRA class wins.  Brought to Monterrey, Mexico and after a full restoration by Jaime Williams, Max raced in the Vintage Series, being the regional Champion in the B Category (Up to 2,000 cc), winning 10 races out of 10, and 9 pole positions. The car has the best components for its class, including parts from Korman Autoworks and Ireland Engineering. Max has raced in numerous other races and always finished in the Podium. Extremely fast and reliable car.
Papers:
- Legally imported into Mexico
- All rights and taxes paid in full
- SCCA Log Book
- Eligible for VSCDA and SVRA
- Group 8
- Racing Log Book with all the specs and settings
- Maintenance Log Book as well.
Engine: BMW M10  2,000 cc
- Arias Custom Pistons (Short, Dome with Fly-cuts)
- Pauter connecting rods (Long)
- Large Stainless Steel Ireland Engineering (IE) Intake and Exahust Valves
- Balanced Crank shaft
- Stage 3 Ireland Engineering (IE) Headers
- Short lateral exahust 3"
- Racing Camshaft Stage 3, (IE-314)
- Double Racing High Tension Valve Springs
- Aluminum spring spacers
- BMW Steel Racing rocker arms
- 2 Weber 45 DCOE Horizontal Carburetors Red Line (Full Race)
- Aluminum Intake Manifold
Oil Cooling System
- Extra large alluminum oil radiator
- All Steel braided atainless stell hoses and AN Fittings
- Accusump oil recovery pressure system
- Remote Oil filter
- High capacity oil Sump with wave breaker
Transmission
- 5 Speed BMW M3 E30 Close Ratio
- Balanced Cardan Transmission Shaft of BMW 320i with rollers and dampers to avoid vibrations.
- Quaife Limited Slip Differential, ratio 3.90:1 installed plus 3 other Differentials
- Tilton Clutch, Double disk, rigid, syntherized with aluminum light weight plate
- Hydraulic actuated Tilton Clutch
- JBR Alluminum Flywheel
- Transmission and Engine Racing mounts
Ignition
- Electronic Ignition Crane XR700
- Distributor with Petronix induction system
- Adjustable Rev Limiter
- Lucas Racing Coil
- Nology Spark plug wires
- Totally new electric system with independent fuses
- Optima GEL Battery
- External Battery connector
- Quick Access fuse box
Brakes
- BMW 5 Series double ventilated discs in front
- Front BMW 4 piston Calipers
- Single BMW Discs rear
- Rear 2 piston calipers Porsche 356b
- Steel lines and fittings
- Tilton precisión brake balance
- Brake front and rear cooling vents
- Racing Hawk KF3 yellow compound high temperature brake pads in all 4 corners
Wheels
- 13" Wide Aluminum light weight 3 Piece Revolution Wheels
- 6 wheels in total all balanced
- Aluminum spacers in 4 wheels
- Large high strength competition studs
Suspension
- Front McPherson with Carrera Custom coil over shocks with racing valving
- Adjustable front and rear anti-roll bars
- Adjustable front Camber Plates
- Racing AFCO coils rear and front
- Height adjustment in rear suspension, NASCAR type (External)
- Rear Shocks Bilstein Nordschleife (Nurburgring)
- Rear "A Arms" with adjustable Toe and Camber
- Inferior front spacers to reduce Bump-steer
Steering
- Original BMW
- Adjustable steering arms
- Racing Sparco Wheel
- Reinforced and extended steering Wheel column
- Quick-disconnect steering Wheel couple
Body
- Light weight fiber glass Schnitzer body kit,
- Front adjusted spoiler
- Light weight fiber glass Boot and Bonnet
- Windscreen, rear, and Windows made of custom anti-scratch
- Front and rear Strut Bars
Security Equipment
- Full SCCA Compliat Roll Cage with 6 support points
- Reinforced plates to anchor roll cage to chassis, extra safe
- 2 Recaro Racing Seats
- 2 Schroth 5 point safety harness with "Quick Release"
- 2 Safety window nets
- Halon Fire extinguisher with aluminum pipes installed and quick release valve
Instrumentation
- Complete Autometer Instrumentation (6 instruments) alluminum bessels
- All aluminum custom made dashboard
-  Oxygen sensor included
Fuel System
- Racing Fuel Cell
- Double independent electric gas pumps
- Double gas filters
- Gas pressure regulator
- All hoses Aeroquip AN
Spares and extras:
- BMW differential 3.64:1 Ratio Weld
- BMW differential 4.11:1 Ratio LSD
- 2 extra Revolution 13” Competition wheels
- Cardan shaft
- Hawk Yellow compound brake pads, several sets of new spark plugs, Engine gaskets, etc.
- Suppliers, addresses, specs, etc. ready
Papers:
- SCCA Log Book
- Group 8
Oil Cooling System
- Remote Oil filter
Transmission
Ignition
- Lucas Racing Coil
Brakes
Wheels
Suspension
Steering
- Original BMW
Body
Security Equipment
Instrumentation
Fuel System
- Racing Fuel Cell
Spares and extras:
- Cardan shaft
How much are you asking?
Rey
Nothing mentioning this car was owned and raced by Robert Dickey from Little car shop in Milwaukee
Then sold to Yan Forsberg in Elkhart Lake .
Rumors floating : car whent  somewhere in Chicago
Look up on the s.c.c.a. log book
Reason i now this ;the team  was : Kat Dickey ,Jenny Morgan ,Don Seefelt ,Jack Fahuna
The car was bought from Alex Rorke from Chicago in 2012 and brought to Mexico. After a complete and documented restoration including engine, transmission, suspension and body work the car took 10 consecutive wins and 9 out of 10 poles in the championship. After winning the championship, the car has been maintained in excellent condition and used for the occasional track day.
Extraordinary coincidence: re the photo of your BMW ahead of the ALFA GTAm tribute #29 - I now own that ALFA and know little of its history other than that  it was rebuilt and raced in Monterrey, Mexico and carries "MOTOR CLUB MONTERREY" stickers.  Do know anything about the ALFA or would you be able to put me in touch with anyone who knew the car? Any help you can give me on this would be very much appreciated. I've attached a current pic of the ALFA. BTW, "Max" is magnificent!
