colorobo2002
weber 32/36 which accelerator jet to use?
4 posts / 362 viewsLast Reply
If the are both 50 then they should, in theory, be the same (0.5 mm).
Not seen the style on the left before.
The accelerator pump nozzle on a 32/36 is blanked off on the secondary side, as it would give the second barrel a squirt any time you pressed the accelerator.  And the second barrel only begins to open when the primary barrel is nearly open all the way, so that squirt into the second barrel wouldn't go anywhere as the throttle plate would be closed.   A two outlet nozzle is used on a 38.38 since the barrels are synchronized.  And if you buy a "Synch-Link" for your 32/36, you'll get a two outlet nozzle as part of the kit.
