Squatch Pads
Upper engine mount - Poly Disintegrated
2 posts in this topic Last Reply
Upon cleaning up the engine bay, and inspecting parts to add to the list of items that need to be fixed, I found the upper poly engine mount literally disintegrating.
I have a rubber lower, what is everyone replacing the upper with now?  Are there better quality poly or is there a harder rubber mount.  Moderately modified motor.
Thank you in advance.
Not an uncommon occurrence....especially if it was an early IE poly mount.  They get to a certain age and simply disintegrate, even seen them do it just sitting on the shelf, un-used.
Put a stock rubber mount in.  Poly is no necesito.  I've had a stock mount on a 292/side draft engine for years.  No problem.
Ed
