Hodgepodge
Please share your body dolly designs...
38 posts in this topic Last Reply
I've seen a lot of you have pulled the suspension during your rebuilds and either used/welded a metal dolly or made a wooden one out of 4x6 or 6x6 lumber.  (And a few of you have rested your cars on tires or other things everybody warns you about....)    I'm thinkning a dolly,firmly attached to the car at the subframe/suspension mount points, would make it much easier to move around in the garage and to trailer to take to media blasting and paint while I work on the removed suspension and other bits. There are a lot of images and Youtube videos on wooden stands, but none specifically for 2002s.   I don't really want to buy a dolly and I suck at welding, but I happen to be an awesome carpenter.   So if anyone has a good design or even good images for a dolly, ideally a wooden one, that works with our cars, please share!
I'm attaching an image of a starting point (properly scaled for a 2002, of course).
Thanks,
Scott
(edited)
Perfect guys.  Scott can we add rotisserie also so I don't have to start a topic and can whack both of them out.   I'll just follow this.
Thanks.
Edit. Nice snug fit Harv. I like that one.
Edited by penth2o
Oh, I do so miss Otis...
('body dolly' indeed!)
jackstands, here, not very exciting.
Oh, wait, the Harbor Freight knockoff GoJax are actually not bad,
having used the real thing before having to buy them myself.
Harv, that stand looks awesome! (Car, too!)  Was it physically attached or is the car just sitting on it?   And did your paint shop put the car on a rotisserie to get underneath?
Eurotrash, your 3-wheeler stand looks almost dainty,  but of course it is made of metal so I'm sure it is strong.
Penth20, Sure, if anyone has a rotisserie option, please include imges of that here!   (There are a bunch of Youtube and Pinterest entries for home-made rotisseries, they are way to large to fit in my garage.  I'm also not taking my car all the way down to the bare body.....at least I don't THINK I am!  :-)
Rapandi did it right on the cheap.
gotta give him credit. Plus he still has his dolly to roll it around.
I took a cue from the Restoration Design videos - how they make a pair of light tubing octagons and are able to combine the dolly function with the rotisserie function.  Plus the cage makes it possible to pick the whole thing up with a chain hoist to get it out of the way or work on it at a comfortable height.
  • Like 3
I had a similar sort of dilemma when I was at that stage of my build - how do I make the shell mobile? I hunted around on Gumtree (craiglist equivalent) for a set of metal sawhorses and I found this chap selling heaps of them for $10 each. I bought a pair - shown below:
I had the front sub frame out of the car so I inverted the saw horses on to the sub frame and marked the corresponding mounting holes which would match the frame rails. Drilled the holes.
DSC_0975.thumb.JPG.4c3a9e963055ec0e54af5bd863e193db.JPGDSC_0984.thumb.JPG.d96bfdc1cf32a2ec939857eb4716f796.JPG
I found that the saw horses were short to span across the chassis bolts that hold the rear sub frame. So I went the scrap yard bought a rectangular hollow section for the price of a coffee and inserted it in to one of the horse like so..... I cut a key hole in the RHS cause that way I had more wiggle room.
Bought 4 rollers with brakes and welded them to the bottom of the horses.
Jacked the car up and bolted both horses to the chassis! IMG_5500.JPG.e3c19e18b54ffeeb1a17618d779a9224.JPGIMG_5508.JPG.fa99d37aba7fc26c05b8a044575913a8.JPGIMG_5505.JPG.5c4f51096688b703e9cec97b34611ee7.JPGIMG_5546.JPG.6f0ef31bea9b2ebe918320a7d0ed3295.JPGIMG_5541.JPG.94f5eed4f540333d8a7da0ae189242f0.JPG
Word of advice - Make sure your dolly is strong and welded properly or if you are using timber then it is bolted and braced well. The reason I say this is because your dolly will face its true test when you have to load the car shell on to a trailer to take to a body shop. Every connection will be tested as the shell is pushed and pulled up an inclined surface. Having a good dolly will be a real blessing. Trust me! You will really thank yourself cause its is so much easier to move the shell around.
I also built a tiptisserie to help me flip the car cause I was sick of lying on my back to remove grime and other stuff off the bottom floor of the car. It was a lot cheaper then buying a rotisserie. After I finished using the tiptisserie I recycled the timber to build some shelves in the garage.
 DSC_0503.thumb.JPG.85e03f2b90dbe5d0b90802ae010cb7c1.JPGDSC_0618.thumb.JPG.4eb68b3390d306f0cbc7e8647eec5730.JPGDSC_0619.thumb.JPG.4893fb7304f13281f6044e22cfbd26e9.JPGDSC_0628.thumb.JPG.5007ba1e159376fd0e4a3ea55fcf55fa.JPG
18 months later the car is still on dolly and painted and I can get under neath really easily too cause my car is about 800mm off the ground too. Have a think about how high you want the car off the ground, size of rollers, how you will fasten the connections. Use nylock nuts where possible etc.IMG_6301.thumb.jpg.d4e0e69a99713e8b68e5b011878d77b4.jpg
Hope this helps. All the best.
Raj
  • Like 3
Barney rigged this up for the 2000CS which shares the same front subframe as an '02, and the rear is almost the same. It's made with galvanized UniChannel/Strut with large steel wheels and casters, with two old subframe mounts welded to the channel in back. It works great and plenty stout.
Ed
(edited)
Rapandi both of your solutions are awesome!   If the sawhorses were mounted to the subframe mount points, what was the tiptissorie mounted too?
I love the rotisserie idea but I am not planning to completely strip the interior of the car and side glass will be staying, I think.
So far the scariests thing about all this is the timing.  I need to have the car oin the road for the Pittsburgh Vintage Grand Prix in July!  (Aaaagh!)
The unichannel stuff is intersting.  I wonder if large sized 80/20 would be strong enough.....we do crazy things with it in robotics.
Edited by Hodgepodge
At the front I mounted the tiptisserie to a set of brackets which attached to the frame rails. Just like how the front bumper brackets attach to the rails. The rails are very stiff to take a torsional effect.
DSC_0411.thumb.JPG.db43bb773d6df9fb3244b07be81f470e.JPGDSC_0431.thumb.JPG.bbb1b06217eb7630240463ed7a2d77f5.JPGDSC_0449.thumb.JPG.522fc32e8d934c39d104a192873b5582.JPG
At the rear the tipptisserie connected to the diff housing brackets. They are stout. I didn't attach to the rear bumper brackets because I was worried they will not be strong on a roundie.
DSC_0612.thumb.JPG.5f406e1678b75638821126d795a4def4.JPGDSC_0626.thumb.JPG.23c191356b110addebd52ec74e1a2924.JPG
