rapandi
Clutch plate size for my 2002tii
11 posts in this topic Last Reply
Hi Team,
I need to purchase a new clutch kit for my 1972 RHD  2002tii. The factory manual says I need a 228mm clutch kit. However it just occurred to me this morning that the PO put a Getrag 245/10 5 speed CR gearbox on the car. This is not factory. Does this in anyway change the size of the clutch I need?
Regards
Raj
IIRC, all tii's had a 228mm clutch.  If your tranny is out, look at the number stamped into the pressure plate. Most likely is a 228.
i kept the 228 flywheel in my 73 when changing to the 5 speed OD tranny.
Yep, they all did....and it's highly unlikely that the person who installed that 5 speed switched to a 215mm setup, as that would involve changing the flywheel for no good reason.
Thanks team. I just need to make sure I get the correct throw out bearing for my car with the clutch kit
(edited)
Thanks, Raj, for initiating this discussion.
I, too, am replacing my 228-mm disk, plate, and bearing in my '74 tii and found the following "kits":
  • Rogerstii:  $312 (Sachs; includes pilot bearing [PB] and alignment tool [AT])
  • Blunt:  $305 (Sachs; includes PB and AT)
  • WN:  $291 (brand? no PB or AT; requires a core and return shipping)
Comments re: these and/or other sources/brands?
Thanks,
Larry
Edited by 2002#2
Forgot to thank initiator of discussion.
None of the kits will likely have the correct bearing for a 5-speed, the 228mm clutch will require a bearing from a e21 323i (part # 21511204525).  I found it is cheaper to buy the kit though and either sell or just don't use the bearing that comes with it (the bearing is for a 4 speed and BMW never offered a 5 speed OD so Sachs doesn't offer the kit with the 5 speed bearing).
So did you source the throw out bearing for the 5 speed separately?
In the aforementioned post re: the three clutch kits, I failed to mention I have an original '74 tii 4-speed transmission (will verify when transmission is removed).  My bad.  I will add a fourth kit (thanks for the suggestion, deanres):
  • Ireland Engineering:  $350 (brand?; includes PB and AT)
Now, may I assume any of these four kits will suffice?
Thanks for the responses.
Yup, purchased separately. Mine is 215mm so it actually uses a different TO bearing than you, one from an E21 320i.
