Bolt hole for right side motor mount bracket
gastephens
The bracket for the right side motor mount attaches to the block with two bolts in the rear and one in the front. It appears that the hole into the block for the front bolt is not drilled / tapped. The car used to have a York a/c compressor bracket mounted there so it was covered up. It does not appear to be a sheared off bolt but it is possible.
Any thoughts or ideas?
BMW Lotus Healey Miata x 2
If it's a 2002 block it must be a sheared bolt all the motor mounts for the 02 used that bolt hole if it's a later m10 it may have not been used but ether way you have some drilling in your future.
George S Patton
Hold on, I'm not entirely sure what I'm looking at.  The right motor mount has three bolts in it.  2 at the rear and one at the front.  The very front hole on my '75 was used for the A/C compressor mount. left side only uses 2.   Here are images of both sides of my motor showing the mount holes, just pulled yesterday and hapily sitting on a stand.
SCH_5951s.thumb.jpg.ba6d406988bc214dea00a279efbd6a5a.jpgSCH_5952s.thumb.jpg.991adc48034f34d5b9623724c69517f2.jpg
Go buy an easy-out bolt extractor.  They work pretty well but I don't envy you having to do it with the engine in the car.
Hope this helps!
Scott
Edited by Hodgepodge
Current: '74 2002,75 2002, 88 E28 M5(2), 92 E34 M5, 02 E39 M5, 01 E39T M5, 08 E93 328i, 08 E61 535i, 09 E93 335i, 09 E91 328ix, 12 E70 3.5i  '67 Alfa Romeo Spider; '69 Alfa Romeo Spider, '08 Dodge 1500 SLT. Past BMWs: '74 2002tii, '74 2002, '76 E12 530i, '78 E12 528i, '85 E28 535is, '93 E34 528iT, '94 E34 528i, '99 E36 328ic (2) '99 E39 528iT, '03 E46 330i convt., '07 E90 328i
Thanks for everyone's help.Yes, Occam is a sharp dude. (razor sharp you might say)
After removing the motor mount and bracket, A/C bracket, and bungeeing the A/C compressor out of the way as far as possible I got enough access to get it out.
Using a right angle drill attachment and reverse thread bits, and lots of Rost-Off and Brakleen, I extracted the sheared bolt!
qOJZ0TBeXImhiRmWQbBuSE-s50j6XrdFi_d3jl-Tcz87TXi6l8HosDHK2zzPGQuyHX1-LoClFkC4Z-IKZ-0dzV2LYjCvQCT5PF5fSoWKdBE7WtRaIqA-NuZEKPoCJd2yRYLiScycRBcop7RY3FFIJS7tkFyJ97CCUqb1zIC3wdFQ9PjDOAMzf53G4xyONkgzylqrCrDmH3scLaI38ts-g74kU7fPbJUIQmbukYehk7VU6lcoLldB484nukMLcdn_HpfwFQ8SeFqkkVeFj8G2ZNpGLySiMPsNYbqLtaKAkVWECXdBwDM_TRbZVaKoxQGTj9weVvjH0eeO_jC2Fn16WrNKLb1D16V1SuYeljHd3suZfZ1ykWaa627TjpzAcvT2Xj98iv9uvnrJj85XElfSBLWmxSkthscVS9p9f5zYjKPn_nYmyQCdi4yOnFBh35ddsmPQCHf0QeKhlE8mt53pbwlkNm9WSdawK34kCIQJCVYgGr1Ra-itwFF6i4_8RW9FwxW1ZkI6kBRjDIVhkSM1Xu_KtOjF-fyF90RvFgwE8kF0yiEl8NHivG3rSwm6XVNd6lvc99bz7wAc6mXprxtd6tdhHc7-xKnigL4N6WkU=w1732-h1299-no
  • Like 5
