mffoster
Sold Lightened 215mm Flywheel
3 posts / 198 viewsLast Reply
Clearing out some extra parts...
OEM steel 215mm flywheel that was lightened to 11lbs when I had an engine rebuilt at Metric Mechanic. Has worked fine on the car for many years (but not that many miles). Just swapped it out for a new aluminum flywheel from Ireland Engineering which is even lighter (about 8.4lbs). No warping, distortion or unbalance. Pictures show the friction surface still shows marks from original Blanchard grinding - no burning or overheating. I’m reusing my pressure plate and keeping the Sachs 2857a0fbd6fae39e6a2518a843960f39.jpg399a92f04e2a1d6d537ab8a639eac7db.jpge1cef93914a15ca4be280d8b69a917c9.jpgclutch disk as a spare. I’m trying the spring center racing clutch from IE as I put this all back together.
First $125 plus shipping takes it!
Mike F
Sent from my iPad using Tapatalk
