Sign in to follow this
Dudeland
Pop-out window tweak
8 posts in this topic Last Reply
I just put in a rear pop-out window seal (successfully) but it needs to be tighter to the bottom seal. I can just slip a piece of paper towel between the seal and the Window.  Any ideas on how I tighten it up?
remember that the inner panel needs
to be installed to push the gasket
toward the glass. the seal should be pushed
into the chrome trim to seat fully.
stone
I have the chrome strip fully seated.  The PO didn't, although the old ones were like gummy dust so it wouldn't have made a difference. Should I shim out the latch to bring it in tighter?
The place where it bolts to the car has a bit of adjustment back and forth. I don't know if it makes it any tighter.  I will have to check.
I have adjusted this with a shim under the latch, a ways forward of where it screws to the body.
In fact, on one car, we used a small rubber bushing between the latch and the rubber gasket.
That latch is cantilevered off the sheet metal, and doesn't really have a good pull on the glass
before the metal starts to deform, either plastically or elastically...
You mean a rubber bushing between the latch and the body. Correct
Yeah, it was just a square chunk of dense rubber, wedged against the lip of the window 'frame'.
