Mechanical fuel pump question
ingramlee
Hi all,
Does anyone know where I might get the nylon spacers like bushings under the washer/nut on the studs that hold the mechanical fuel pump in place.  Mine have deteriorated into pieces when I removed the pump for my rebuild. How critical are they?
Thanks
(1973 Fjord Blue 037) Vin 2588314- Build date February 6th, 1973- delivered to Hoffman Motors NYC February 8th.
They do deteriorate, don't they?
It's called a top hat bushing, or stepped washer.  I bet the bolt bins at your local auto parts store or Lowes/Home Depot might have something that works.  If not, a quick Google search found these on fleaBay  http://www.ebay.com/bhp/nylon-bushing
Good luck... I should probably get some, myself.
Ed
'69 Granada... long, long ago
'71 Manila..such a great car
'67 Granada 2000CS...way cool
Thanks ZINC... I have seen those at the local hardware store and will grab a couple before I fire the car back up. I went ahead and mounted the pump without then as I wasn't sure how critical they are.
Many - myself included - replace the mechanical pump with an electric, and cover the hole in the head with a plate.  I put mine in the trunk, for minimum pickup difficulty and convenience.  Plus, it made sense with two tanks (used an RV solenoid operated fuel selector valve).
Noisy - yes, but mounting it on rubber bushings will silence most of that.
Good luck with the bushings.
Andy the tail light guy says "Be Seen, and Not Hurt!"  [mailto:mobrighta@comcast.net]
Lighting Upgrades for E3, E9, E10, E12, E21, E23, E24, E28, E30, E32, E36, E39 - front & back
Tail Light upgrades keep them off your tail, out of your trunk;
Headlight film keeps your 'eyes' from being scratched out or broken.
