Window guide sliding piece
echappe
The white nylon sliding piece that appears to be NLA, #17 ; is there a replacement part that can be used for this
Sponsored links
FRONT WINDOW GUIDE
No. Description Supp. Qty  From   Up To  Part Number Price   Notes
01 BRACKET LEFT   1     51326654165     ENDED
01 BRACKET RIGHT   1     51326654166     ENDED
03 WINDOW GUIDE RAIL LEFT   1     51321813181 $42.18
03 WINDOW GUIDE RAIL RIGHT   1     51321813182 $42.18
04 Rubber seal   X     51326540282 $9.69
05 WINDOW LIFTER FRONT LEFT   1     51321801135 $125.50
05 WINDOW LIFTER FRONT RIGHT   1     51321801136 $125.50
06 CONICAL SCREW   2     51211800790 $0.67
10 CRANK   1 03/1966 04/1972 51326646115     ENDED
11 Stop disk SCHWARZ 2     51321819852 $6.12
12 CONICAL SPRING   2     51321870460 $1.19
13 Pin   4     51321829986 $5.34   ENDED
14 Pin   2     51321829989 $1.10
15 FRONT WINDOW GUIDE   X     51326654262 $68.24
16 Clamp   6     51321817560 $1.07
17 SLIDING PIECE   4     51326454347     ENDED
18 Holder   2     51326454165     ENDED
19 WINDOW GUIDE RAIL LEFT   1     51326454154     ENDED
19 WINDOW GUIDE RAIL RIGHT   1     51326454155     ENDED
20 Bush   4     51327041760 $2.09
21 Distance rubber   2     51326454169     ENDED
  • 4 months later...
  • 5 months later...
  • 1 month later...
For part #17 I would suggest finding a piece of UHMW (ultra high molecular weight) polyethylene, and get a Dremel tool. That plastic machines easily, is self lubricating, and tough as nails - it may be what the original part was made from. The material used for 3D printing wouldn't work nearly as well for this application. Rather than use an additive process (printing), a subtractive process (milling machine - or Dremel tool if you're not making 100s) using the right material would work better IMHO.
Koboldtopf - '67 1600-2
Einhorn - '74 tii
