Healey3000
Question about the Metric Mechanic transmission bracket
3 posts in this topic Last Reply
Hi,
From Bill Williams' photograph in a previous post, it appears that the MM bracket hangs down below the gearbox a fair bit.  I assume that's to allow for box movement.  If any of you MM users happens to know how much that underhang is, I'd appreciate knowing.  Is it now the lowest part of the undercarriage or does the exhaust pipe still win that honor?
Thanks!
Thanks.  I think the bellhousing lip sits well below the bottom of the flat part of the gearbox.  I'll have to go check.  If the brace stays within that distance, all is well.
You are commenting as a guest. If you have an account, please sign in.
  Only 75 emoticons maximum are allowed.
