Jetting for 40 DOAC webber carbs
Guest Ian
Hi I have a 1976 2002 with 40 DOAC  weber carbs
The car is weekend street driven for pleasure
I am having problems with the proper air/gas mixtures and wanted to know what would be the best jet setting for this type of driving
I cant remember what is in there now and I am not a true technical guy so any suggestions /help would be well appreciated.
Thanks
Ian
Firstly do yourself a favour and get an Air Fuel Ratio Gauge (AFR). It makes live infinitely more easy.  AEM sells a good one for about $165, and you get a local shop to weld in a bung.
It will tell you where it is rich and lean.  I couldn't have ironed out my problems with my 32/36 without it.
Regards
"Goosed" 1975 BMW 2002
This is the one that I'm running in my "02". I HIGHLY recommend some type of "Wide band 02 sensor". I wish I would have known about these back in 1997 when i started racing circle track with the (4)-44mm Mikuni round slide motorcycle carbs. Tuning would have been WAY easier than just trying to do spark plug readings by eye....
https://www.summitracing.com/search/product-line/innovate-db-digital-air-fuel-ratio-gauge-with-lc-2-kits?SortBy=Default&SortOrder=Ascending&tw=innovate db&sw=Innovate DB Digital Air%2FFuel Ratio Gauge with LC-2 Kits
Remove the main & Idle jets under the little "hat" and read the numbers on all parts and also look at what chokes are fitted inside each of the air intakes . Research will tell you what I mean  its a pair of Weber 40 DCOE 's you have fitted . look in YouTube , always some good how to's on there
1970 4 speed 2002 (Daily driver/track car )
1974  Hybrid powered twin cam engine, Pig Cheeks , ( now a round tail.) Getting ready to Sell
"I don't remember what I have in there"
It takes 5 minutes to look.  Pop off the hats and get in there with a flat blade.  Altitude, season, heat and timing all affect jetting.
You need to know
Accelerator pumps
Idle Jets
Mains
Airs
Emulsion tubes
Chokes
45 idles
125-135 mains
200 airs
with 32mm chokes is a good start for a 9.5:1 street motor with a cam
A set of jets will run you about $50 so it pays to know what you have
