Carburetor
braceface
Yes, I like my Weber 32/36 on my 74.  I get about 17-22 mpg.  About 9 mpg on the track.  On the freeway and streets here in SoCal it is just fine.
As an aside, I will say that I've been thinking a lot about changing to a Weber 38/38 for more power on track days.  But its a slippery slope for me from there.  Next I'll want a bigger cam (292), and vented disc brakes of course to go with the additional HP.
Here is a chart to guide you towards 170+HP and away from MPG.
1974  02  Inka
1975  02  Chaminoix (parts car)
1995  318ti  Hellrot
Yeah, the Weber 32/36 is pretty much the universal choice for replacing the problematic Solex two barrel.  Lotsa discussions on the FAQ WRT jetting, tuning etc.  I've had one on my '73 since 1981or so (when my Solex died!) with few problems--and I get 22-25 mpg around town and flirt with 30 on the highway with a 5 speed--that's with a 284 cam and 9.5 pistons.
Quote
I have run both on the same car- there's not really any difference in lap times
until you get quite a ways down the rabbit hole with performance modifications.
The 32/36 flows a lot,
and the 38/38 flows a bit more, but what you really notice is that the
38/38 is not progressive, so you have about 3/4 rated power at 1/4th throttle,
whereas the 32/36 doesn't even start the secondary until about halfway open.
So the 38 FEELS like a lotta power, but only because it all happens at the beginning.
  • Like 4
I have a 32/36 in my 4-speed '75.  It is perhaps the only thing that I haven't needed to fiddle with on the car, but I am replacing the stock manifold with a cannon, so I may end up fiddling with it after all. (I'm not doing that for more power, just because I think it looks much cleaner and there are fewer holes to plug.)  I get decent mileage and pretty good power.  It's easy to service and nowhere near as complex as, say, dual DCOE Webers (I have an Alfa with them).  I've owned other 2002's including a tii.  Honestly, for everyday driving and occasional track days, a 32/36 is probably fine.  On the highway, I don't think I could tell the difference between a 32/36, 38/38, dual DCOE or even a tii with a 4-speed.  Like others have said, it is a slippery slope to get more out of your engine.
Hope that helps.
Current: '74 2002,75 2002, 88 E28 M5(2), 92 E34 M5, 02 E39 M5, 01 E39T M5, 08 E93 328i, 08 E61 535i, 09 E93 335i, 09 E91 328ix, 12 E70 3.5i  '67 Alfa Romeo Spider; '69 Alfa Romeo Spider, '08 Dodge 1500 SLT. Past BMWs: '74 2002tii, '74 2002, '76 E12 530i, '78 E12 528i, '85 E28 535is, '93 E34 528iT, '94 E34 528i, '99 E36 328ic (2) '99 E39 528iT, '03 E46 330i convt., '07 E90 328i
Interesting.
At the track I’ve been looking for a little more power out of the corners and onto the straights. (Maybe less entry braking is required).
On the street there is really no need for anymore. I’m at least as fast as most cars on and off the freeway. Passing not so much.
I’ve been told that the times I’ve been running with my 32/36 at the track would put me at the back of the VARA pack of DD 38 ‘02’s. Not bad for a non race prepared 02.
My setup is pretty straight forward:
1st factory overbore and pistons
stock cam
3.64 Diff (not LSD)
4 speed
Stage One Suspension
14” wheels w/falken tires
shorty exhaust header (IE?)
Just to be clear and stay on topic,  I am happy with how my car drives with the 32/36.
I’m really only thinking about marginal low cost improvements at the track.  I bet my times would improve if I relaxed a little more and didn’t fight the car quite so much. Momentum.
1974  02  Inka
1995  318ti  Hellrot
Plus 1 on what Toby just said
If you have a stock motor, you should be happy with the 32/36 out of the box
From my experience, I have a 32/36 on a motor with a 284 cam and it needed some re-jetting.
With a 5 Speed it gets 27 + mpg on the highway
My other car with a 292 cam and a 38/38 is very happy and more fun to drive. It also cold starts and runs with little or no choke which I like.
Again with a 5 speed there doesn't seem to be a significant loss of MPG.
+1 to what Toby and Clark said. For a stock motor and around town driveability stick with the 32/36.  38/38 is only beneficial once you have a bit more aggressive camshaft and are up high in the revs, but it's true that it feels much different as it gives much more throttle for much less pedal input.
Yeah this is my around town daily driver, stock motor so I'll go with the Weber 32/36.  Thanks everyone!
If you get one, make sure that you get WOT.  I just had to adjust the bracket connecting the gas pedal to the arm to make sure I would get full motion.  The PO wasn't that "detail focused" what I mean by that is it was slapped together.
Thankfully that was the last little bit that needed to get sorted out... for now.
Regards
"Goosed" 1975 BMW 2002
