dashboard removal/installation
Rexford75
Hi,
I am relatively new to the web site.  I am in the process of restoring a 1976 2002. I recently purchased a parts car that was in a barn for the past 20 years.  Among other things it has a mint, crack free dashboard that I want to remove and put in my car.
Does anyone have any helpful tips, instructions, what not to do, etc. on how to remove the dashboard.  I have everything around it removed - cluster, glove box, center column (radio, ash tray, hazard switch) and steering wheel & cover as well as all the screws I can see from under the dash.  Thoughts on next steps?  Does the windshield need to be removed?
Any help would be greatly appreciated.
Thanks,
Doug
Unfortunately for this type of dash removing the windshield is all but necessary.  The dash is held in place by 2 (?) screws underneath the windshield gasket.  If you don't mind destroying the windshield gasket and risking damaging the dash it can be done without removing the windshield but not easily.
BMWCCA  Member #14493
www.2002sonly.com
windshield has to come out period--imho---Done a dozen or so and tired with a bent philips---there just wasn't any clearance. You can leave the screws out on the re-instal--but i will stand by the fact that the glass has to come out on a 74-76 dash removal
Me too. I have seen referrals to the bent screwdrivers so I guess someone must have succeeded that way. Not gonna try that myself after seeing how the screws are located.
On ‎1‎/‎15‎/‎2018 at 9:39 AM, esty said:
or it can be done without ruining the dash or rubber if you'll use a short, right angle phillips screwdriver
WOW!
I didn't think of that, the last gasket I had installed I pulled those 2 screws just in case for the future
I don't take myself or opinions Seriously
My 4th 2002 and the first set of Square Tail-Lights
See the 4 versions of my 2002 project here: SoCal S2002 | Facebook
You might get lucky.........during the stripdown/rebuild of my Touring I noticed that there never were any screws there (no holes in the dash, only the metal support).
Les
'74 '02 - Jade Touring (RHD)
'76 '02 - Delk's "Da Beater"
FAQ Member #17
No need to remove the dash if you have a short screw driver you can angle in there.  And no need to replace the screws. The dash is not going anywhere without them and I feel they add additional restraint that may be causing the common cracks you see in that area.
75 2002 polaris 2365430
88 325ix zinnoberrot
8 hours ago, esty said:
Les...hows your touring resto coming along ?
Hi Esty,
It's pretty much done; I really need to send you some pics of the carpet; looks great. As soon as I can get it out of the garage (snow-cold).
Les
Les
FAQ Member #17
  • 5 years later...
I have a 1971 1600 and dash is cracked. is there any known suppliers where this can be purchased as a replacement. I have not seen any through my search on the internet. Also wondering if a replacement can not be purchased, what is the best way to fix? link to articles or videos would be nice.  also open to possible taking it to a professional who does this regularly but this seems it would be very difficult. I live close to Seattle and Spokane Washington if that helps. Thank you.
Check @vintagedashes on instagram. they're reproducing the 2002 dash and may have 1600 dash too.
2003 e39 M5 (daily)
1986 e30 325es (sons car)
