rdotson Posted November 26, 2017 Share Posted November 26, 2017 Hello. Help. 1975 2002 manual. Just finished motor rebuild. Runs and sounds fine. Now when I hit ignition, nothing. A faint click and silence. Only part I didn’t replace was the starter of course. 50,000 car. Took it off but it checks “good” at the store. Does that check the solenoid? 12v to starter. Solenoid lead only reads 8.5v when on. Low? Bad switch? Still the starter? What am I missing. THANKS. RD Quote Link to comment Share on other sites More sharing options...
Simeon Posted November 26, 2017 Share Posted November 26, 2017 You got the engine ground sorted after the rebuild? Quote Link to comment Share on other sites More sharing options...
dlacey Posted November 26, 2017 Share Posted November 26, 2017 Do you have an earth strap to the engine? Are you sure the battery is good? Seeing only 8.5 volts means the starter isn't getting the power it needs. Quote Link to comment Share on other sites More sharing options...
Bibm5 Posted November 27, 2017 Share Posted November 27, 2017 +1 for bad ground Sent from my SM-G930P using Tapatalk Quote Link to comment Share on other sites More sharing options...
chargin Posted November 27, 2017 Share Posted November 27, 2017 +1 for bad battery Quote Link to comment Share on other sites More sharing options...
Brandon Posted November 27, 2017 Share Posted November 27, 2017 10 hours ago, chargin said: +1 for bad battery I second the battery. Quote Link to comment Share on other sites More sharing options...
Tdh Posted November 27, 2017 Share Posted November 27, 2017 Agreed on bad battery, but just for laughs double check your terminals to make sure they're clean. I've got a triumph that's famous for doing exactly what you describe because the terminals get cruddy just on the inside area where they make contact with the battery posts. Quote Link to comment Share on other sites More sharing options...
TobyB Posted November 27, 2017 Share Posted November 27, 2017 +1 for DVM (Digital Volt Meter) t Quote Link to comment Share on other sites More sharing options...
Mike Self Posted November 27, 2017 Share Posted November 27, 2017 Quick way to check as to whether it's the battery or the starter: turn on your headlights, then turn the key to "start." If the lights go dim, then the battery is weak. If the lights stay bright, it's either the starter or the wiring (and relay) between the ign key switch and the starter. To test that, run a jumper wire from the + terminal on the battery to the small terminal on the starter. If the starter still doesn't work, the problem is either in the starter or a bad ground (or a bad + battery cable/connection). If the starter now works, then the problem is in the wiring or in the starter relay. mike 1 Quote Link to comment Share on other sites More sharing options...
