Correct Turbo head
m6smitten
Is it important to have the car original spec.?
How far down the modification "rabbit hole" do you want to go?
How would you achieve 7.5:1? Why not 9.6:1 like a Euro Tii?
Preyupy stole a bit of my thoughts, but one can determine the difference in off boost power, as well as BMEP on boost.
I think your knock frequencies would change, if you do that kind of thing.
Your fuel curves might need to change too, but would have to check.
Not to offend, but was it tuned properly to begin with and were you happy with it before taking it apart?
Would you consider changing the rear ratio to achieve similar results, like a 3:46? CR 5 speed?
I always liked the "docility" of motoring around under vacuum, then when you need to get going you down shift, rev up, and go. It is what the Turbo is.
I am still rebuilding my engine, and will keep the 6.9:1
That's it for now.
