mataku527 Posted November 16, 2017 Share Posted November 16, 2017 Since I've had the car, I've had a whistling sound that comes from the driver side. It is only present when I'm going more than 30mph. Opening the windows don't make a difference, putting my hand over the roof rail doesn't seem to do anything, I put my hand all over the antennae and it doesn't seem to do anything. Any thoughts or common causes? Quote Link to comment Share on other sites More sharing options...
JerryC Posted November 16, 2017 Share Posted November 16, 2017 I believe Mr. Mike Self would suggest applying blue masking tape to various potential whistle sound sources (one or two at a time) until the whistle goes away to isolate the sound source. Use the tape to temporarily block air flow over suspect sound sources, such as trim gaps, windshield gasket edges, and so forth. Once you've found the source, making the noise go away is likely to be fairly easy. Quote Link to comment Share on other sites More sharing options...
Lorin Posted November 16, 2017 Share Posted November 16, 2017 It's probably the front hood belt line trim. Quote Link to comment Share on other sites More sharing options...
yeewiz Posted November 16, 2017 Share Posted November 16, 2017 just my guess, but since the window position has already been ruled out, that only leaves the front vent window, or rear window, or door seal. that masking tape idea is a great one Quote Link to comment Share on other sites More sharing options...
ray_ Posted November 16, 2017 Share Posted November 16, 2017 10 minutes ago, yeewiz said: just my guess, but since the window position has already been ruled out, that only leaves the front vent window, or rear window, or door seal. that masking tape idea is a great one Or the mirror Or the antenna Or the door/fender gap Or the wipers Or... Quote Link to comment Share on other sites More sharing options...
jmiller Posted November 17, 2017 Share Posted November 17, 2017 As above ^^^ check the front belt line trim. I had the same problem; sounded like a jet turbine, coming from the windshield, or door. Felt like it was right next to my head. Passengers were making jokes about me and my old car! Put tape all over everything until finally I determined it was due to a gap in the front belt line trim. Replaced the rusty fastener there, tightened it up, problem solved. Quote Link to comment Share on other sites More sharing options...
ray_ Posted November 17, 2017 Share Posted November 17, 2017 ... or the sunroof Well I guess I better tape up all those holes on my missing beltline trim now... Quote Link to comment Share on other sites More sharing options...
conkitchen Posted November 17, 2017 Share Posted November 17, 2017 Woo Wooo West Coast represent Beeotches. Cooper's town OG 2 1 Quote Link to comment Share on other sites More sharing options...
yeewiz Posted November 17, 2017 Share Posted November 17, 2017 (edited) well sounds like gonna need a lot more masking tape than originally planned Edited November 17, 2017 by yeewiz 1 Quote Link to comment Share on other sites More sharing options...
al Posted November 17, 2017 Share Posted November 17, 2017 I just had my car painted and all the trim removed and replaced, somewhat poorly, and now I know why it's called the whistling bomb. It was definitely making a high-pitched whistle before, but I thought it was coming from my carburetor. I noticed the upper trim along with the antenna wasn't fastened perfectly and I plan on giving The blue tape treatment to see if that's the problem Quote Link to comment Share on other sites More sharing options...
robspeed Posted November 17, 2017 Share Posted November 17, 2017 Try the 2" wide stuff... ;-) Quote Link to comment Share on other sites More sharing options...
ray_ Posted November 17, 2017 Share Posted November 17, 2017 I'm gonna try the yellow tape instead. ;-) Quote Link to comment Share on other sites More sharing options...
landon Posted November 17, 2017 Share Posted November 17, 2017 There is a small rubber seal that goes on the top of the door at the front edge that may be missing? If you see the sheet metal edges there then it's not present. I believe that can cause some wind noise. Quote Link to comment Share on other sites More sharing options...
John_in_VA Posted November 17, 2017 Share Posted November 17, 2017 1 hour ago, landon said: There is a small rubber seal that goes on the top of the door at the front edge that may be missing? If you see the sheet metal edges there then it's not present. I believe that can cause some wind noise. There is a similar seal for the rear top edge of the door, too. Quote Link to comment Share on other sites More sharing options...
mataku527 Posted November 18, 2017 Author Share Posted November 18, 2017 Looks like it will take some time to figure this out. I was hoping to make my 2002 my daily driver, but with my usual drive about 5 minutes and hearing how short drives are not good for the car, I only take it out on the weekends. I'll get working on some of the tips above. Maybe we should compile a post or list of the most common sites so that it'll be easy to find for the next person. Gonna start with the beltline trim. Wish me luck! Quote Link to comment Share on other sites More sharing options...
