mbaum.collects@gmail.com Posted November 5, 2017 Share Posted November 5, 2017 Suddenly at 3800 RPM oil pressure spikes never did before I usually shift at 5000RPM now anything over 3800 pegs the gauge Any thoughts here? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
TobyB Posted November 5, 2017 Share Posted November 5, 2017 Stuck pressure regulator in the pump. Not uncommon. If that's true, it should be temperature dependent- as in, cold, it spikes lower, after a long fast highway run, it should be higher. The fix is to drop the pan, pull the pump, and either replace or have the regulator bore sleeved. The steel piston galls the aluminum bore. t Quote Link to comment Share on other sites More sharing options...
mbaum.collects@gmail.com Posted November 5, 2017 Author Share Posted November 5, 2017 Thanks Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
