mbaum.collects@gmail.com Posted November 5, 2017 Share Posted November 5, 2017 Can all of this be removed throughout the engine compartment in 1976 2002? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
'76mintgrün'02 Posted November 5, 2017 Share Posted November 5, 2017 nope. that'd be an oversimplification. there are wires inside the sheathe that you will need, such as the points/condenser wire, the oil pressure wire, possibly an idle cut off solenoid wire, coil resistor wire, tachometer wire... maybe more? Quote Link to comment Share on other sites More sharing options...
Stevenc22 Posted November 5, 2017 Share Posted November 5, 2017 On a 76 you will have atleast 3 wires left. A power wire for the coil (resistance wire), the negative which goes to the tachometer and then the oil pressure wire. Quote Link to comment Share on other sites More sharing options...
Dudeland Posted November 5, 2017 Share Posted November 5, 2017 Also, you need the wire going to the carb, the electric choke/idle cutoff runs through the blue sheath. Quote Link to comment Share on other sites More sharing options...
