rapandi Posted November 5, 2017 Share Posted November 5, 2017 Hi Team I am looking for a warm Up Regulator for my KF Pump. My current one is not functioning well. Regards Raj Quote Link to comment Share on other sites More sharing options...
shermanmartinez Posted November 6, 2017 Share Posted November 6, 2017 Remove it and clean it. You need to change your coolant more often! Hopefully you can get away with just cleaning it. It looks like it is simply clogged up from all the minerals in your coolant. You have been using ONLY distilled water with the anti-freeze/coolant right? shermanmartinez at hotmail dot com Quote Link to comment Share on other sites More sharing options...
rapandi Posted November 7, 2017 Author Share Posted November 7, 2017 9 hours ago, shermanmartinez said: Remove it and clean it. You need to change your coolant more often! Hopefully you can get away with just cleaning it. It looks like it is simply clogged up from all the minerals in your coolant. You have been using ONLY distilled water with the anti-freeze/coolant right? shermanmartinez at hotmail dot com I have only had the car for a short while but PO certainly has had poor antifreeze habits. I will try and clean it for sure and see if it works. If I can find a better one then may opt for that. Quote Link to comment Share on other sites More sharing options...
