Road trip Posted November 5, 2017 Share Posted November 5, 2017 Would anyone know if the 1972 Europa radio is what’s know as single DIN ? Quote Link to comment Share on other sites More sharing options...
Simeon Posted November 5, 2017 Share Posted November 5, 2017 No, it is a 'spindle mount' which had a range of standards whereas the DIN size is a single standard which is in use today for modern stereos. Quote Link to comment Share on other sites More sharing options...
esty Posted November 5, 2017 Share Posted November 5, 2017 Simeon, i disagree...the older becker body is mounted in a standard DIN case even though the face is shaft style/push button operation...one DIN size opening works Quote Link to comment Share on other sites More sharing options...
Road trip Posted November 5, 2017 Author Share Posted November 5, 2017 38 minutes ago, esty said: Simeon, i disagree...the older becker body is mounted in a standard DIN case even though the face is shaft style/push button operation...one DIN size opening works Your right, does this mean I can swap any single din Radio ? i have the car set up as original for show and I just want to temporarily swap the radio out for long trips Quote Link to comment Share on other sites More sharing options...
Tsingtao_1903 Posted November 5, 2017 Share Posted November 5, 2017 Not sure if you can without some work. Modern car radios single DIN or not have standard plugs combining power, switch power, front/back speaker wires... that plug directly to the back. The Becker Europas have separate speaker wires with special plugs and power wire going into the back. I had a modern radio that I removed and had to redo the power & speaker wires to connect to the Becker. Quote Link to comment Share on other sites More sharing options...
esty Posted November 5, 2017 Share Posted November 5, 2017 3 hours ago, Road trip said: Your right, does this mean I can swap any single din Radio ? i have the car set up as original for show and I just want to temporarily swap the radio out for long trips as stated above, if you can power the one you want to swap in temporarily...you could always jump a set of wires that will work with either when needed a modern single DIN radio and a Becker will both fit the same DIN mount sleeve/bracket 1 Quote Link to comment Share on other sites More sharing options...
Simeon Posted November 5, 2017 Share Posted November 5, 2017 Well, there you go. I guess it seems obvious that the German radios may comply with a German standard, even if the rest of the industry went their own way. Quote Link to comment Share on other sites More sharing options...
HBChris Posted November 6, 2017 Share Posted November 6, 2017 Europas with spindle/shaft mount exist but are extremely hard to find nowadays as opposed to Blaupunkts which were shaft mount. Quote Link to comment Share on other sites More sharing options...
