J Mart Posted November 3, 2017 Share Posted November 3, 2017 I see a lot of talk about the 5 SPD conversion with the Getreg 265. But My son and I found Getreg 260 5SPD's to replace the standard 4 SPD's My question is there are a number times that you need to do or get ( shorten Drive Shaft, Enlarge Tunnel, Change Clutch Cylinder, etc. etc. But what are the other items that need to be done to complete. 1 What about shifter and shifter platform, does the stock one work or do you have to modifiy the 5 SPD one ? does it need to be cut down if so how and where does it need to be cut down at ? 2 Throw out bearing does this need to be changed to a different one for the 5 SPD ? 3 Transmission support, there seems to be one for the 265 that you can buy but no one talks about the 260 ? 4 electric speedo conversion because the 260 does not have a cable drive ? Is there a kit and what needs to be changed in the dash We are new to the conversion so this is why I am asking. We are going to convert 2 cars at the same time his 73 and my 69, which I have to convert the pedal box from manual to power These are the burning questions Jeff in PA Quote Link to comment Share on other sites More sharing options...
TobyB Posted November 4, 2017 Share Posted November 4, 2017 A getrag 260 out of an E30 will not bolt to an M10- they're M20 and later bell pattern. There may be one with an M10/30 bell pattern, but I had thought that was called a 265, with the removable bell. all I got. t Quote Link to comment Share on other sites More sharing options...
Trax Posted November 13, 2017 Share Posted November 13, 2017 You need the Getrag 260/6 from an E28 535i, that one will bolt up. It's known for its durability. It wont fit in your tunnel since it's the same size as a Getrag 265. Quote Link to comment Share on other sites More sharing options...
