1Eighteen Posted November 3, 2017 Share Posted November 3, 2017 I am trying to fit new seals into the rear quarters, but I am struggling with them. Is there a trick to getting them to fit. I can do the bottom edge fine, then you start with the run up to the Hoffman kink, but the rubber just will not stay in after that. When I move onto the straight run after the kink, I just cannot get the seal to push behind the window frame. I also have some plastic bodywork tools, but still struggling. I can see exactly how it is supposed to fit, but there must be some sort of trick to actually getting them in place ?? Could someone also advice if these seals are glued at any point ? Thanks guys and gals. Quote Link to comment Share on other sites More sharing options...
Mike Self Posted November 3, 2017 Share Posted November 3, 2017 I did a column some years ago on this installation, part of the general refurbishment I did on my '69 back around 2001. PM me if you'd like a copy of the column. IIRC I had to do a bit of trimming and finagling to get the seal in place. But it's been hanging in there ever since! cheers mike Quote Link to comment Share on other sites More sharing options...
02Les Posted November 3, 2017 Share Posted November 3, 2017 Hope when you finally get them in, they fit better than my new ones. The rubber is a lot softer than the originals. Quote Link to comment Share on other sites More sharing options...
1Eighteen Posted November 3, 2017 Author Share Posted November 3, 2017 1 hour ago, mike said: I did a column some years ago on this installation, part of the general refurbishment I did on my '69 back around 2001. PM me if you'd like a copy of the column. IIRC I had to do a bit of trimming and finagling to get the seal in place. But it's been hanging in there ever since! cheers mike Thx Mike. PM sent. 1 hour ago, mike said: Quote Link to comment Share on other sites More sharing options...
1Eighteen Posted November 3, 2017 Author Share Posted November 3, 2017 wow. 02Les. That looks bad. Are you sure they're not damaged ? Quote Link to comment Share on other sites More sharing options...
nbcbird Posted November 3, 2017 Share Posted November 3, 2017 Start at the kink first (get it good and snug) and work towards each end. The ends need a lot of intricate trimming to fit the B pillar. Quote Link to comment Share on other sites More sharing options...
02Les Posted November 3, 2017 Share Posted November 3, 2017 1 hour ago, 1Eighteen said: wow. 02Les. That looks bad. Are you sure they're not damaged ? No they are not damaged. Both sides are similar with the gap in the same place. These were bought through BMW to get away from URO.......so much for that. I'll not wash the car or take it out in the rain!!! They are actually sedan seals that I had to extend, as BMW, in their wisdom, made the Touring ones NLA. Quote Link to comment Share on other sites More sharing options...
Dudeland Posted November 4, 2017 Share Posted November 4, 2017 6 hours ago, mike said: I did a column some years ago on this installation, part of the general refurbishment I did on my '69 back around 2001. PM me if you'd like a copy of the column. IIRC I had to do a bit of trimming and finagling to get the seal in place. But it's been hanging in there ever since! cheers mike Can I have a copy of the column, please. I am about to tackle this once I get some fuel issues ironed out. Quote Link to comment Share on other sites More sharing options...
echappe Posted November 4, 2017 Share Posted November 4, 2017 10 hours ago, Dudeland said: Can I have a copy of the column, please. I am about to tackle this once I get some fuel issues ironed out. I also would like a copy, Thanks Quote Link to comment Share on other sites More sharing options...
D.martijn Posted November 5, 2017 Share Posted November 5, 2017 On 3-11-2017 at 8:50 PM, 02Les said: No they are not damaged. Both sides are similar with the gap in the same place. These were bought through BMW to get away from URO.......so much for that. I'll not wash the car or take it out in the rain!!! They are actually sedan seals that I had to extend, as BMW, in their wisdom, made the Touring ones NLA. Hey Les, I received the reproduction Touring seal, still need to find some time to get it all fitted and tested out before the guy will start producing more. I'll let you know when these are for sale Quote Link to comment Share on other sites More sharing options...
1Eighteen Posted November 5, 2017 Author Share Posted November 5, 2017 Well. I have almost got there with these, wow, it's hard work to get these in !! But I have managed to fit them without any trimming or cutting (apart from the B pillar end) which is intended to be cut !! And, that's where I am at. I am unsure how to properly trim the end to allow the glass to fit without leaking or breaking !! It is virtually impossible to squeeze it in there as it is now ? Anyone ? I also know I have to trim and fit the B pillar rubber, before anyone points it out !!! Quote Link to comment Share on other sites More sharing options...
02Les Posted November 5, 2017 Share Posted November 5, 2017 5 hours ago, D.martijn said: Hey Les, I received the reproduction Touring seal, still need to find some time to get it all fitted and tested out before the guy will start producing more. I'll let you know when these are for sale Great. Yes, please let me know when available. Quote Link to comment Share on other sites More sharing options...
1Eighteen Posted November 5, 2017 Author Share Posted November 5, 2017 Back to square one with these !! I thought I was there. Trimmed the seal at the B pillar, fitted the glass and did a dry run with the 'U' trim on the inside and the seal decided to remove itself from the kink !! Bloody things !! Took me most of the fkn day !!! Quote Link to comment Share on other sites More sharing options...
