2000Touring Posted November 1, 2017 Share Posted November 1, 2017 Can anyone tell me which rims are on the picture? Do they fit the BMW 02? They are 13 inch and are 4×100. Quote Link to comment Share on other sites More sharing options...
resra Posted November 2, 2017 Share Posted November 2, 2017 Looks super cool but the offset looks to be close to 0 I would be concerned with the fitment. Otherwise looks like the correct bolt pattern and hub bore. Quote Link to comment Share on other sites More sharing options...
Conserv Posted November 2, 2017 Share Posted November 2, 2017 The optimal offset for an ‘02 is generally 25 to 29mm. Depending on their age, the offset may be cast or stamped into the rims. Otherwise, you need to measure the offset. Regards, Steve Quote Link to comment Share on other sites More sharing options...
jrhone Posted November 2, 2017 Share Posted November 2, 2017 45 minutes ago, Conserv said: The optimal offset for an ‘02 is generally 25 to 29mm. Depending on their age, the offset may be cast or stamped into the rims. Otherwise, you need to measure the offset. Regards, Steve That depends on the rim width. Front or rear. As well as tire size. Quote Link to comment Share on other sites More sharing options...
