5 speed Driveshaft length
jrhone
The diff can be moved backward or forward a small amount to compensate for slight variations in length--the rear sub frame diff holes are slotted to allow this, as is the center bearing mount carrier. That said, I'd want to measure my own application before ordering any driveshaft. --Fred
On 10/29/2017 at 4:04 AM, J Mart said:
Not to highjack the conversation but does anyone know what the length would be on a 260 5spd drive shaft. I have both drive shafts 3 and 4
Not sure but would be nice to know if anyone on here knew. I know getrag 245 on the M20 is about 56.5” and getrag 240 on M10 is about 62”.  It mostly comes down to what M20 motor mounts you are using,  some put the motor closer to the firewall than others.
Edit :  my measurements are flange to flange. NOT to the tip of the nose
Edited by 02tradition
