john02md Posted October 27, 2017 Share Posted October 27, 2017 Is there any value, or harm, to hogging out the 2 holes into 1 for use with a Weber 32/36. I know it is recommended for the heavier breathing 38/38. Thanks, John '74 Polaris Quote Link to comment Share on other sites More sharing options...
Mark92131 Posted October 27, 2017 Share Posted October 27, 2017 As long as there is no restrictions to the opening of the throttle plates on the Weber 32/36 with the 2 hole intake manifold, you should be good to go. There certainly is no harm in hogging these out, unless you don't properly flush out the aluminum shavings and they end up in your combustion chamber. Any value, possible improvement to the flow of gas/air mixture through the intake manifold. This was an BMW OEM modification in the "Peanut" manifold, so someone at BMW thought it was a good idea. Mark92131 Quote Link to comment Share on other sites More sharing options...
jireland2002 Posted October 27, 2017 Share Posted October 27, 2017 No harm. In fact it is a good modification. It increases the volume of the plenum and should have a small improvement in performance. Quote Link to comment Share on other sites More sharing options...
'76mintgrün'02 Posted October 27, 2017 Share Posted October 27, 2017 I asked this question a while back and got the opposite advice... which I took to heart. Quote Link to comment Share on other sites More sharing options...
jimk Posted October 27, 2017 Share Posted October 27, 2017 I wasn't going to post. Got tired of trying to discuss the topic and why the effort doesn't accomplish much if not the opposite of what was expected. Nobody seems to have any dyno results of only the pre and post grinding effort to prove their point. Hole size matching is one thing, Creating a sudden expansion is another. 2 Quote Link to comment Share on other sites More sharing options...
rstclark Posted October 28, 2017 Share Posted October 28, 2017 The other worthwhile improvement is to take the manifold off the engine and port the intake runners to match the intake ports of the head which are larger that the manifold. Taper them back in the intake runners about an inch and a half Don't make them bigger that the head ports as that could be counter-productive. After removing the manifold, look at the intake manifolds gaskets , you will see the impression of the miss-fit. 1 Quote Link to comment Share on other sites More sharing options...
