deez2002 Posted October 26, 2017 Share Posted October 26, 2017 If anyone has an extra setup lying around. My rod linkage is crap. Thanks Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
wegweiser Posted October 27, 2017 Share Posted October 27, 2017 (edited) Pierce Manifolds sells the linkage you seek. One change in the production I've noticed, is that the plastic bell-crank on top, must now be drilled (carefully) so that the cable can exit it, after being clamped by the tiny barrel nut, and thus adjusted easily. Without drilling, it's HELL trying to get the cable "just right". If I can find a photo of this detail, I'll attach it.... (searches hard drive for linkage photos.....) See how 4mm of the cable end is visible in this photo? I had to drill the black bellcrank myself, to allow this. If you try to install it "dead ending" inside the bell-crank...you will drive yourself nuts. Takes 10 minutes to modify. Edited October 27, 2017 by wegweiser Quote Link to comment Share on other sites More sharing options...
bimmerdotcom Posted October 27, 2017 Share Posted October 27, 2017 Thanks for sharing Paul Saul www.bimmer.com 1 Quote Link to comment Share on other sites More sharing options...
