Car Lift opinions needed
Dudeland
2 hours ago, grizzlebar said:
I'm giving some thought to going this route: www.myliftstand.com
Looks like a set of 4 is $520
I don't see the point of those stands. What do you do when you want to take off one or more wheels? Once it is up that high, it's pretty hard to manage if you want to then put an axle stand under one corner.
You might as well get 4 x drive on ramps.
rtheriaque wrote:
I have had the 5000 pound version that runs off 12v for about 6 months.  Works perfectly in my garage or at the track.  Love the portability and convenience.  Lifts the 2002 like nothing and it is very stable.  The 12v runs fine off a jump box or the battery in the car.  I am amazed at how little juice it uses.  Don't hesitate getting one.
Those are interesting but how do you use them for work that involves removing the wheels?   About 85% of what I need a lift for is wheel, brake or suspension related.
I've always like the post lifts but don't have room for a permanent one.   Here is one that can be mounted to the floor and then removed when not in use.  Probably a bit of a storage issue, but at least it can be moved around.  Won't work at the track, though.
MaxJax Portable
Thanks,
Scott
Edited by Hodgepodge
Current: '74 2002,75 2002, 88 E28 M5(2), 92 E34 M5, 02 E39 M5, 01 E39T M5, 08 E93 328i, 08 E61 535i, 09 E93 335i, 09 E91 328ix, 12 E70 3.5i  '67 Alfa Romeo Spider; '69 Alfa Romeo Spider, '08 Dodge 1500 SLT. Past BMWs: '74 2002tii, '74 2002, '76 E12 530i, '78 E12 528i, '85 E28 535is, '93 E34 528iT, '94 E34 528i, '99 E36 328ic (2) '99 E39 528iT, '03 E46 330i convt., '07 E90 328i
I think I am going with the 5000lb option with the 12V pump.  If you happen to have to jack up a car away from power, you will still have an option.   It will be a little less slick when using it in a garage.
http://www.quickjacklift.ca/car-lift-systems/bl-5000slx-portable-car-lift.html
"Goosed" 1975 BMW 2002
On ‎10‎/‎23‎/‎2017 at 10:18 AM, John_in_VA said:
Here's some info about the EZcarlift that a friend put together while using it with his E28: http://www.ezcarlift.com/
http://www.mye28.com/tech/rods_pages/continued/id25.html
Actually, I like this route better after reading a fair number of negative reviews for hydraulic based systems.
There is a downside though... it can't lift my truck :/
In the time I have mine I haven't see a drop of fluid leaking.  I think some of the first connectors did leak some but that has been fixed for quite some time.
1975 non-purist driver M42 Turbo, Hurricane a/c, and all sorts of cool stuff
1976 2002 sold, 1970 2002 sold, 1969 1600 sold
