flat6fan Posted October 22, 2017 Share Posted October 22, 2017 Long time lurker now owner of a 71 2002 that I plan on turning into a daily driver. If has some rust in the lower Pass qtr panel so I need a patch panel for this. Also lower rocker on pass side at the wheel opening rear needs patched or replaced. I could use beltline trim, Front grills, maybe lower trim may delete, Drivers door, this one may can be saved but if one is available may be better off to replace. I am in Georgia but travel the southeast for work and could pick up if in AL, GA, TN, SC,NC etc. Thanks Phillip Quote Link to comment Share on other sites More sharing options...
ray_ Posted October 22, 2017 Share Posted October 22, 2017 Check with W&N also https://www.wallothnesch.com/en/body-work/bmw-1502-2002-turbo.html 1 Quote Link to comment Share on other sites More sharing options...
Bibm5 Posted October 23, 2017 Share Posted October 23, 2017 Long time lurker now owner of a 71 2002 that I plan on turning into a daily driver. If has some rust in the lower Pass qtr panel so I need a patch panel for this. Also lower rocker on pass side at the wheel opening rear needs patched or replaced. I could use beltline trim, Front grills, maybe lower trim may delete, Drivers door, this one may can be saved but if one is available may be better off to replace. I am in Georgia but travel the southeast for work and could pick up if in AL, GA, TN, SC,NC etc. Thanks Phillip I just did a trim delete on my 74 2002 and I'm in GA also. My trim isn't perfect but it's still usable. I was going to clean it all up and then list it in the next week or so. If you're interested in anything just pm with offers.Did you need wheel arches also?im about to do rabbit fenders so mine will be up for grabs soon. Sent from my SM-G930P using Tapatalk Quote Link to comment Share on other sites More sharing options...
02Les Posted October 23, 2017 Share Posted October 23, 2017 PM'd you. Quote Link to comment Share on other sites More sharing options...
flat6fan Posted October 31, 2017 Author Share Posted October 31, 2017 Still looking. Quote Link to comment Share on other sites More sharing options...
