Help identifying Getrag 245
NB02 er
I have found a local Getrag 245 for sale however I need some help determining if it is the proper one to fit my car.       Have a 1976 2002.  It is not the tii or ti
The current owner says its from a 1983 320i.   I've read that I should look for the date of manufacture but I don't see it anywhere
looking for some help
From the picture you posted, that's an earlier 5 speed with the three piece case--essentially a 4 speed main casting with a 90mm long plug to contain the 5th gear and its synchronizer.  Will work just fine in your car with the usual mods--shortened shift platform, shortened driveshaft with 3 bolt guibo mount, relocated or U-shaped rear tranny mount, and longer speedo cable & clutch slave cylinder flex hose.
Lots of writeups on the details in the archives.  And you'll love the 800 rpm drop between your current 4th gear and the overdrive 5th.
