Ultimate relays and fuses upgrade
AustrianVespaGuy
In my updating of my 76 project I have added 4 power accessories in the cabin as well as A/C.
In the Engine Bay I've added relays for Driving lights, Airhorns, Electric cooling fan which all had inline fuses, I HATE inline fuses.
For my interior accessories I added a powered 6 mini fuse block which is now all full:
Hated the way the inline fuses make everything look hacked in:
I added a 6 mini fuse Buss, I still need to tape everything up to clean it clean:
  • Like 4
I don't take myself or opinions Seriously
My 4th 2002 and the first set of Square Tail-Lights
See the 4 versions of my 2002 project here: SoCal S2002 | Facebook
Yeah, I've always felt in-line fuses were really amateur league, so I personally applaud your revamped solution! :D
@pato2002 OT, but how did you go about supporting your air filter?  My setup is about the same and I use a little block of wood screwed to the filter with a hole in that mates with a bolt coming through the front clip sheet metal, which works surprisingly well, but curious if there's 'a better mousetrap' solution out there!
17 hours ago, pato2002 said:
I haven't finished yet but also used that 5-relay, 6-fuse box from Amazon and also bought a 10-fuse ATC box that I installed using a 3D printed adapter plate and some jumpers.
Looks like it should be there, especially on an EFI setup.
OK, some quick answers/ photos.
For the 10-fuse block, I bought this one and am quite pleased, It is good quality construction. If you cannot make the adapter, they have another that has the spades on top.
To connect it, I made some short (~3in) pigtails with male/ female spade connectors. It is pretty tight but I didnt really want to cut all the originals. There may be a more elegant solution.
Honestly, I would not recommend the 6-fuse, 5-relay box. It it fussy regarding the connectors and is pretty cheap construction. I will be looking for a nicer solution but live with this for now.
To support the filter, I printed a U-shaped saddle that press-fits onto the bumper bolt. I may add some glue for security but it fits tight and does a good job of supporting the filter. That said, I haven't put any miles on it yet. I will look for a better photo tonight. If you want the file, let me know.
Lastly, no one asked but I highly recommend this cable wrap. Soooo much better than tape or the cruddy corrugated tube.
1974 BMW 2002 (in progress)
1987 Porsche 911 (mostly complete)
Blog: Broken Boomerang
That’s awesome. Can you share the 3D print file?
Here's what I've bought so far:
Bussmann 15303-4:  Will hold 5 relays and 10 fuses
Littelfuse HWB18:  Wild hold 3 relays and 3 fuses
Lots of Delphi Weatherpak connectors
800+ ft of TXL wire (12,14,18 GA in 11 colors)
The Bussmann will be relocated under the dash.
The HWB18 will replace the 2 relays for the lights + my electric fan relay in the engine compartment.  I'm going to hide it in the headlight area.  The horn relay will be moved inside.
3 of the 12 original fuses are for the headlights which I'm moving to the engine bay (fused off the battery)  There's also one for the rear defrost that I don't have on my car, so that's 4 of the 12 that can go.
I think for relays on the Bussmann, it will be:  2 for ignition, 1 for fuel pump, 2 for extra.  I might remove one relay to add two more fuses, then I could have 1 relay and a couple fuses for an EFI system later on.
I'm still trying to figure out where to put the 22-pin Delphi bulkhead connector though, it's way bigger than I thought.
John Baas
1976 BMW 2002
2001 BMW M5
My Blog!
Fuses is mostly a personal preference thing depending on how you plan your wiring, but for relays in general I can provide the following guidance:
1.) Low beams
2.) High beams
3.) Horn
4.) Cooling fan
5.) Aux lights
6.) Fuel pump
7a.) 'Green wire' hot in Run&Start for misc. 'stuff'
7b.) 'Purple wire' hot in Aux&Run for misc. 'stuff'
8.) A/C
