Berk Ergin
5,123 posts / 386216 viewsLast Reply
14 hours ago, theNomad said:
Made some progress. AGM battery mounted under seat and wires made for relocation.
Question: is the 250A circuit breaker overkill? Is it totally unnecessary, a possible problem, or is it perfectly fine as a safeguard feature? I saw some have used them so picked one up.
Also have positive cutoff wired in.
Where should I mount the neg cable?
I'm thinking of just drilling another hole in the foot panel/bulkhead since I don't want to drill the body or pans and I can easily patch the holes I've already drilled in that panel5407215669d2ef2570a0758e96db0711.jpg20593e556af35c12754655b8de71e36c.jpg
Sent from my SM-J327VPP using Tapatalk
I have my battery under the back seat as well.
I have a battery cutoff mounted exactly like yours.
I have a 150 amp inline fuse.
My negative is bolted directly to the floor pan but anywhere with thick metal and solid welds should be able to accommodate the negative terminal.
On 11/4/2019 at 7:40 PM, theNomad said:
What setup are you planning to use? Looks like MS? I've got a Speeduino ready to go in. Just need a few more sensors and some fabrication. Will be prepping the wiring system first.
I was planning on using MS3... but I haven't bought it yet. Pricey.
Does Speeduino support forced induction and all that? If so, that would be really cool to try.
Does it support all the same setups with the EDIS4 ignition and bosch injectors, etc?
Going to do some reading up of my own, but if you know off the top of your head...
Actually, if you could PM me that would be awesome. :)
Hello
I took out the brake shoes of “1972 AT”.
The side brake cam was stuck to the brake shoe.
Working my way though the front end repairs On my 72tii fjord blue, removed a front corner from parts car / prepped it for reinstall and roughly fit duck bill repairs..
  • Like 5
41 minutes ago, ray_ said:
Go Barney!
Ceylon car done yet?
:D
Barney is a man on fire!!!
Jason
Finally making progress again. At least the interior is going back in after all the wiring is run.
Will be upgrading the fuse box but I'll attach all the battery wiring first and fire it up. The carpet looks much better than those flash pics
Crank and pistons installed.  I’ve been thinking about my ignition lately,  which distributor should I use? 1981 320i head.
  • Like 3
I am thinking on the MS3 gold box. I will look into the Speeduino, got my PI installed in my console already.
I got up this morning around 4am (no idea why). Started working on the 02.  Struts!!!!  I had purchased a spring thing tool (to contract springs) and on the 2nd try ( yeah,  no one said, “Be careful where you place the spring thing.  Use the 2-3rd coil) I was able to compress the spring and line up the indents where the end of the coil of the spring finalizes.  I have photos:
Edited by Toca
  • Like 3
Got the car back Wednesday after a long six months. Rick and the crew at North Bay Bavarian in Santa Rosa did a phenomenal job on the engine compartment cleanup, wiring, and engine rebuild. Car really runs strong, Jenvey and EFI, really pulling well. Really pleased with how everything turned out. Really pleased with the Speedhut gauges as well. A few minor oddities but all in all really pleased.
Sent from my SM-G973U using Tapatalk
Edited by 69Bimmer02
Add pictures
  • Like 4
Great driving roads up here in NorCal up to lake Berryessa!  Just loving rolling over the odomoter we are blessed with this life and to be able to enjoy these great cars!IMG_2859.thumb.jpg.066d55c8b5a5983b37432ab6329126e6.jpgIMG_2864.thumb.JPG.29385b4ed22764036e4b27a2b910ad2f.JPGIMG_2858.thumb.JPG.967bfd7a82994d981455768bcbacc56f.JPG
Looking good scott. Hey we are planning for a Reno/ Tahoe drive on 11/22..Let me know if you would like to drive with the Sac SH02 group.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Lets get it! Shoot me a text. Are you guys going to Sunday Neue Klasse and Kaffee? Trying to make both Los Gatos and Sacramento meets!
