5 hours ago, '76mintgrün'02 said:
I changed the oil in the transmission for the first time since I first did it 11 years ago.  The old MTL was still kind of red and this seems like a reasonable amount of filings for so much use.  (?)  I'd pushed the metal off of the top of the magnet, to better gauge the amount.
It was fun to finally get to use the plug wrench I found to remove the fill plug.  Technically, it is a VW wrench with a 21mm box on the other end.
The first 50 mile test drive proved that the odometer is working again.  That's a handy feature.  The valve adjustment and distributor servicing have improved how it is running.  I am a little concerned with how lean plug number one looks though.  It's a bit whiter than the others.
The photo was from before the valve adjustment and I'm using 5 series NGK plugs.  I wonder if 6 series would have more tan coloring.  Number three had the loosest intake valve.  I wonder if that's why it's tan.  I suppose I should probably pull them again.  (and try spraying ether around the #1 intake)
Tom
I have one white plug on my tii's motor as well, which freaked me out a bit at first.  But I can't detect any detonation and the car runs flat cold.  Then I pulled all the plugs on an e28 535 and they were ALL just as white, and it ran like a MoFo.  So I'm wondering if I should be trying to get them all that color!
‘74 Fjord 2002tii (Zouave)
’80 Alpenweiss 528i (Evelyn)
’05 R53 Chili Red Mini S
‘56 Savage Model 99 in .250-3000
31 minutes ago, ray_ said:
Yes!
No you can't have it.
:P
Okay!  you win.
Don
12 hours ago, Leucadian said:
We ended up using an AGM battery, not sure the exact brand, but I believe it's just a generic AGM mount, bolted to the floor
That is a Odyssey 28L battery. An excellent battery. I run the Odyssey PC680 under my back seat.
My project has stalled waiting on my booster and injection pump to come back from rebuilding. So in the mean time I'm just making projects like cleaning up the wheel wells.
  • Like 7
Crankshaft Enema
PROBLEM:  Crankshaft Blockage
SOLUTION:
  • 1 slice of whole grain bread*
  • 1 drift (of sorts)
  • 1 BFH
  • 5 patient minutes of persuasion
RESULT:  Oh, sweet relief!
* For some reason 12-grain works better than 8-grain.  Must be the special fiber in those 4 additional grains.  Next time I'll use bread made from Super Colon Blow** grain...won't even need a hammer.
**  www.youtube.com/watch?v=Ku42Iszh9KM
  • Like 3
  • Haha 3
45 minutes ago, 2002#3 said:
Crankshaft Enema
SOLUTION:
  • 1 BFH
I used this very same method (though with gut blocking white bread) on my crankshaft with the narrower needle bearing and it worked beautifully.  Much easier cleanup than using bearing grease.
Karl B.
1974 2002tii Malaga ("Conrad") -->> Conrad's Restoration Blog
2003 330i ZHP 6-spd
2011 328i xDrive
Getting texted by friends at Monterey is NOT cool…
but does serve as inspiration!
Engine time!   Finished the bay prep, including fitting the brake fluid reservoir and bending a new matching clutch master feed pipe.  Also zip-tied the brake residual pressure valve.
Note the engine mount locations with the 02 Underground mounts (inspired by the old 02 autohaus setup).
  • Like 12
I finally got around to pressure washing the carpet today, after having removed it a month or so ago, due to spilling coffee under the passenger seat.  The compressed air nozzle probably removed more dirt than the pressure washer.  I hung it up and could see the dirt and water blow out with the sun shining through from behind.  It was a messy job, but satisfying at the same time.
No photos of that process, but I did take some when I dealt with the rust I found after taking the carpet out.  That was another messy job.
After a bunch of scraping, sanding, wire wheeling and grinding, I washed it with OSPHO and scrubbed that in with a scotchbrite pad before finally wiping it dry.  Paint tomorrow.
  • Like 8
Savannah 02 Gruppe met up for cars and coffee. I think it is a building year. Good to see Ray and Mark. I will be going to more of these. D3358DBE-9E59-44D4-AA5D-39B36303A040.thumb.jpeg.ed68d324d3e77718fe6a676567316b21.jpeg
'76 Stone Gray 2002
'83 blue R80RT, '83 red R80RT,
'16 Alpine White Xdrive 328d Touring
BMW2002FAQ #502
