Got the window back in and working. Without touching the door hinge bolts in the process, now the door doesn’t lineup right anymore.  WTH.  I have to slam it to close now.   Is the weight of the glass & door hardware enough to do that?  Weird.
I finally got around to installing the adjustable alternator bracket I bought from Themis (great seller btw) and installed a new belt to stop some squealing.  Just wondering, how hard should it be to turn the fan by hand.? Definitely a little harder with new belt. Belt has teeth on outside thick part so it’s on right :)
Edited by Fortlauderdalian
do you have the plastic corn kernel on the latch?
Door latch bumper part number help - BMW 2002 and other '02 - BMW 2002 FAQ
George S Patton
Looks good from here.  I'm enjoying watching all you have done on your car.  Not seeing a side view passenger side mirror yet but I think I see the mounting holes.
eric
8 hours ago, uai said:
Next Step would be these
Please let me know when you want to get rid of them-- especially if you are having financial distress and are desperate.
What is the difference between your 400 and mine? Is yours a bit earlier? Mine has the full chrome hinge, and no headrest.
Those adjusters look like a nice product.  Don't make the belt too tight though, or it can cause the alternator and water pump bearings to wear prematurely.
Are the pulleys running parallel to each other?
Did you replace the rubber bushings in the alternator while you were in there?  They get gooey when exposed to oil and then the pulleys go out of alignment, causing belt wear and squealing.  There are polyurethane bushings available that last longer than the rubber ones.
Tom
I'll let you know, but there is already a queue for these seats...
The only BMW related seat I'd part with at the moment is this here. Original BMW Material
Finally got around to replacing the door brakes with new parts from Harry Davis. Pretty simple and what a nice improvement over the free swinging old doors.  Best I can tell the door cards had never been off and doors are 100% original, broken parts laying in the bottom!
1 hour ago, Fortlauderdalian said:
I’ll go and look at the others. I’m guessing I have to remove the alternator to get to them?
They fit into the alternator body at the pivot point.  I wouldn't bother to remove it if the pulleys line up.
If the belt isn't running straight between the pulleys you might as well order replacement bushings.  It won't hurt to run it as-is in the meantime, if it's just a little off.
19 hours ago, 7502 said:
Is this statement true if the window is rolled down?
Yes.  I think I found the problem and I'm pretty sure I know how to fix it, but remain stymied as to how it occurred.  It was shutting smoothly before I put the window mechanism and glass back in.  It’s binding at the top front of the door.   A comparison between the working drivers door and this one (passengers) in pics
IMG_5734.MOV
Edited by Fletcher
didn't finish my sentence
