I found a deal on a 1975 mostly original mellow runner while picking up parts in Venice for @Coastalcrush408. I felt like I couldn’t say no to it... so today I brought home a sibling for the 1969 2002, the 1984 E28 hot rod, and the 1965 Hillman Imp.
My ownership might be temporary (something's gotta go), but for now I like it...
Edited by hellayego
  • Like 9
1965 Hillman Imp - Rosemarie
1969 BMW 2002 - Dolores
1975 BMW 2002 - Rolf
1984 BMW 533i Swap - Alfons
11 hours ago, Buckeye said:
Hardware was mounted incorrectly. This way guibo was already twisted  and centrifugal force helped it to explode quicker.
It was mounted by Patrick @ Midnight Motorsports over a year and some change ago. Had about 8 thousand aggressive miles on it. I don’t remember details but I think he was advocate of later style mounting with all bolts in same direction. Which I guess is point to be  debated.
I picked up "PB&J" from the shop after an engine rebuild and other work... what a difference! I'll add for good measure it was smack dab in the middle of the heat wave occurring now (heat index on the road was 105) and I'll state once again what an essential item A/C is IMHO, it made the drive SO much more enjoyable. PB&J will be seeing over 3000 miles in August alone ?
Edited by fastricky
  • Like 7
Please explain.  Motor mounts?  Transmission mount?  CSB?  Those are the 3 variables for alignment on a stock car.
I suppose the diff could be too far forward as well.  The bolt pattern would not affect alignment.
73 Inka Tii #2762958
Finally did my set of super cool reproduction 'flaps yesterday. These are a nicely made product and such a deal
I lost the instructions but once I stared at a few pics on the FAQ it became a
snap. I did add some lock washers...The key to this job is to make sure you
get plenty of bite when mounting the 'teeth'. I didn't want them flying off with
the first cat (pick a mammal) I ran over
Prep  involved a serious wire brushing and some de greaser + some vinyl pro-
tectant for the 'flaps
I love these. Somehow Anna has a bit of class now.
Edited by iinca
  • Like 5
Today I finished refurbishing tail light assemblies of the '70 project '02: re-coated housings, cleaned contacts, and installed new rubber seals and standard bulbs.  Tail, brake, turn, and back-up lights are glowing brightly (for an '02) and when told to do so.
Larry
IMG_8273.thumb.jpeg.be520f449ef2959f7c8a1b2fef3150eb.jpegIMG_8286.thumb.jpg.d5a47ea3aef411c1efa17ceacbde9742.jpg
  • Like 4
The reason the bolt heads should be on the guibo and the nuts on the flange, is when you tighten a nut/bolt assembly, you are supposed to hold the bolt head still and tighten the nut.  If you tighten whatever end that touches the guibo, you risk rotating the metal insert and putting strain on it.
Edited by xr4tic
  • Like 4
John Baas
1976 BMW 2002
2001 BMW M5
My Blog!
Been trolling that ad for months. Hope you got a better deal than offered to me.
Still, kinda, interested in that '69.
I don't give a fird gen, carbretted, alyoominiuhm, tickity boo!... wiff an ole in the boot!
Installed correct fuel line vent and grommet. Painted the instrument cluster ring that holds the glass in satin black. Also painted the inside of bezel satin white.  The front glass trim rings are off to get new silver pin striping  done. little steps ?
