That is a fun video.
How are you relieving the pressure when the car is shut down?
Do you have the stock fuel diverter inline still?
My theory is that upon shut down, the remaining fuel pressure has to either go past the float needle in the carb (flooding the manifold), or back through the valve in the pump; or both.
I use the Jeep filter, with two outlet nipples and use the second one to vent that pressure/fuel back to the tank through the steel return line under the car.  I think it helps.
I assume you have new fuel lines/clamps coming off of the tank, in the trunk; as well as the spacer sleeve (not cracked) on the sender's outlet nipple, ya?
I sure am glad we're friends nowadays [emoji16]. Your theory seems to be very accurate if not spot on. Just went down to the garage (stinks like gas in there, pregnant wife not happy) and it looks like gas has definitely been flooding into the manifold. Looked at what I now know is the diverter valve and it turns out the fuel return line is kinked. I'm thinking it happened when I pulled the battery a few weeks ago to make swapping the master cylinder a little easier. So if I unkink that line should cure the issue? Or at least partially remedy it?
All fuel lines are new and sender spacer and clamps are good. Proud to say "no gas smell in the trunk". cb80ab56bdd1901afc667d97f051e999.jpg8ffbee2a7f0f536574d62c423131e3ab.jpg
Sent from my SM-G960U using Tapatalk
Picked up my patched fuel tank. He brazed in the holes and then sealed it in and out. Looks like he went crazy with the inner sealer but over all I am pleased and I think I doubled my cars value as it was done for $250 .
old and what I got back.
  • Like 6
Slowly building a $20,000 $4000 car
If it "ran when parked" you wouldn't have parked it!
I fit both my doors tonight and started on the seals. Moving it in and out of the garage as coked up the plugs lately so it was running on 2-3 cylinders. I had them out cleaned them up and boom! it runs like a dream ?. I can't wait to get some miles on the clock.
  • Like 8
Those wheels are amazing...
Message me for 2002 Koozies!!!
