friends ..... and their mechanical skills
This is probably being used as a air compressor. I bought a 32 Chev business coupe that was set up as a field sprayer compressor with 1/2 the cylinders left in running condition and the others supplied compressed air thru the exhaust  it looked a lot like this set up.12919869_1006309922737787_32213083278264
Edited by Son of Marty
Can't speall
George S Patton
2 hours ago, '76mintgrun'02 said:
Did you find this one in a STANCE thread?
12592585_1006309992737780_46680776199943
Sheesh, the things people will do to (ruin) a car's suspension to achieve the LOOK they are after!
I'd say that's corrosion.  Stance would want the suspension mounting point higher.
  • 5 weeks later...
4 hours ago, carlkkreienkamp said:
The one with the wrench in the fan housing looks like a type 3? type 4?  VW  pancake engine
That's a turbocharger impeller.  The cooling fan on a type 3 and 4 VW is much larger and doesn't have a band clamp.
Did they file the battery posts to get the cable barrel of the terminals installed. They must really have been in the shit and needed to paddle out.
rtheriaque wrote:
